Mr Elco please help with Z400 Hello. When i connect the Z400 With the d800 cable, all is ok but NSPRO respond "phone not found". The phone is powered on. Thanks in advance. |
z400 1 Attachment(s) uze ns-pro adapter diagram from support |
Thanks but it's not a problem with power USB. Z400 is not Detected "phone not found". May be it's the sam problem... |
in DEVICE MANAGER move modem port at 2-9 port and try again this must work BR |
OK but i don't have modem in device manager. I put the d800 cable in NSPro (not USB). I have only com port from NSPro box (com 71). And i have "not detected" |
The phone must be powered on and must be detected by PC as Samsung CDMA Modem. If you get "USB Power exceed" problem, use Zxxx adapter. |
if i connect phone with D800 Rj45 cable "phone not found". If i connect with d800 original cable "detecting usb connection....... Bypass msl security.......... Detecting phone......... operation failed!" I haven't powered message. With USB Original cable, WMA modem is detected. What's the problem? |
If you get "USB Power Exceed" problem on NsPro, use Zxxx adapter. If you dont get that problem and the phone is not detected by NsPro, check for hardware faults on your NsPro box or try with a different NsPro D800 cable. |
1 Attachment(s) Nspro Usb Power Exceed |
