Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 06-16-2007, 12:05   #1 (permalink)
Member: 9866
Mr Elco please help with Z400
Hello.
When i connect the Z400 With the d800 cable, all is ok but NSPRO respond "phone not found". The phone is powered on. Thanks in advance.
Old 06-16-2007, 12:41   #2 (permalink)
Member: 108215
Thanks Meter: 10
z400
uze ns-pro adapter diagram from support
Old 06-16-2007, 14:29   #3 (permalink)
Member: 9866
Thanks but it's not a problem with power USB. Z400 is not Detected "phone not found". May be it's the sam problem...
Old 06-16-2007, 15:13   #4 (permalink)
Member: 47236
Thanks Meter: 58
in DEVICE MANAGER move modem port at 2-9 port and try again this must work
Old 06-16-2007, 15:47   #5 (permalink)
Member: 9866
OK but i don't have modem in device manager. I put the d800 cable in NSPro (not USB). I have only com port from NSPro box (com 71). And i have "not detected"
Old 06-16-2007, 18:30   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
The phone must be powered on and must be detected by PC as Samsung CDMA Modem. If you get "USB Power exceed" problem, use Zxxx adapter.
Old 06-17-2007, 11:15   #7 (permalink)
Member: 9866
if i connect phone with D800 Rj45 cable "phone not found". If i connect with d800 original cable "detecting usb connection.......
Bypass msl security..........
Detecting phone.........
operation failed!"
I haven't powered message.
With USB Original cable, WMA modem is detected. What's the problem?
Old 06-17-2007, 11:48   #8 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
operation failed!"
Phone cant be unlocked usong only USB cable. You must use NsPro box and D800 cable.
If you get "USB Power Exceed" problem on NsPro, use Zxxx adapter.
If you dont get that problem and the phone is not detected by NsPro, check for hardware faults on your NsPro box or try with a different NsPro D800 cable.
Old 06-18-2008, 20:54   #9 (permalink)
Member: 109642
Thanks Meter: 6
Nspro Usb Power Exceed
Mr. Elco Please Help me.......! Alway's show File Courupted amol_sm NSPRO 12 02-17-2009 18:50
Mr.Elco Please Help D720 Security iletmek NSPRO 3 11-14-2008 11:09
Ms.Elco please help with X820 Roni1976 NSPRO 9 01-06-2007 14:14
Elco Please help with P735 mashi NSPRO 13 03-07-2005 01:51
Page generated in 0.22291 seconds with 11 queries
