11-13-2013, 16:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Note3 n9005 when will be possible repair Samsung Account/Imei?? tx BR Max |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
11-14-2013, 06:12 | #2 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | coming soon elco perpair for i9500 new security and note3 unlock solution |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
11-17-2013, 00:23 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | There is just support for this phone ..... have protection in writing from first register whith Samsung Account, impossible Apply any other Fw flashed, accept w/o problem but immediate go in autoprotection and not show any menu', ....will be how iphones 7.03Fw?, no iTunes psw no iphone?... Note3 N-9005 is very good phone but have need urgent solution for this block of SAMSUNG ACCOUNT |
The Following User Says Thank You to .:Ripgsm:. For This Useful Post: |
03-03-2014, 12:18 | #6 (permalink) |
Junior Member Join Date: Jan 2009
Member: 939257 Status: Offline Thanks Meter: 0 | Anything can make "default" efs file with .tar or .md5 (flash with Odin) for N9005? If after flashing I will see yellow text on desktop, SN null and etc. Same like I9100EFS .tar Just for N9005. It's possible now to do? |
03-03-2014, 12:52 | #7 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
i not understand where is you problem now, but if is briked you can restore only whith BOOT CARD .immage file, after this go in D.Mode can write Full Flash whith Single file + mx-Pit, phone is restored NOTE: IMEI/SN NULL IT'S BAD eMMc PROBLEM, HW Problem, can try whith procedure above but if you have BAD eMMc you never can repair w/o replace it, br allumts | |
03-03-2014, 13:45 | #8 (permalink) |
Member: 939257 Status: Offline Thanks Meter: 0 | Thanks for reply. I need EFS to reset some settings (pattern lock enabled, need remove). I can't full flash, root, flash custom recovery or reset phone. Only way is reset EFS folder with EFS_tar and Odin or nsPro flasher. For i9100, i9300 I did it fine, whey have EFS (downloaded over nsPro). |
03-04-2014, 08:43 | #9 (permalink) | |
http://forum.gsmhosting.com/vbb/f777...8/#post9927536 br | |
03-04-2014, 10:35 | #10 (permalink) |
Member: 939257 Status: Offline Thanks Meter: 0 | It's not reactivation lock. It's forgotten Pattern lock. Now show "Enter unlock PIN". I need remove lock and save photos. I don't want root (will be knox 01). If I would flash EFS, then will be lock removed without data lost. Maybe is another way to save data (photos)? Some ways I know, but need root (custom recovery) device. |
03-04-2014, 14:02 | #11 (permalink) | |
W/O Debug Usb you cannot remove pattern lock, so, i'm not sure that u can solve in New Security only writing EFS and no lost data... i not know this for 4.3 New security and in this case for N9005 | |
03-04-2014, 14:09 | #12 (permalink) |
Freak Poster Join Date: Feb 2011 Location: tunisia
Member: 1517638 Status: Offline Sonork: 100.1620436 Thanks Meter: 33 | goo down and go accessibility and open text-to-speech options and install any voice data will ask u to make new samsung account and when done than go sin it with it |
03-04-2014, 14:17 | #13 (permalink) | |
but you have read good?...him have "ENTER UNLOCK PIN" when first screen appaer, you solution is MY SOLUTION and is for REACTIVACTION LOCK | |
07-23-2014, 13:51 | #15 (permalink) | |
Br allumts | |
