Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 12-27-2005, 22:31   #1 (permalink)
Member: 105625
NSdongle crashes when unlocking E730 using box
I just got the NSDongle box, but it did not work very well...
- I select E730 (NSdongle box is selected).
- Press unlock
- Connect D500 cable to the E730 (which is switched off)
- Phone switches on displaying "Charging"
- Nothing happens - after about 20 seconds NSDongle crashes
Running Windows XP, and NSDongle 3.9.6
And it's pretty annoying that other COM ports are not available when NS-box is connected.
Please make it possible to select other com/jaf connectors, even when NSbox is detected.
Edit: I tried manually updating the dongle (using exe in NSdongle directory - this didn't autostart like it usually does), but still it doesn't work using box. But application shows unlock failed instead of crashing now. Unlocking using normal COM worked fine.
Old 12-27-2005, 23:43   #2 (permalink)
cellularman's Avatar
Member: 150246
i have the same problem with e730 and the nsbox...
Old 12-28-2005, 18:46   #3 (permalink)
Member: 105625
Elco, can you please check this?
Old 12-28-2005, 20:48   #4 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
PLZ uninstall Nsbox drivers and reinstall them exactly like i have explained in tutorial. Also try to connect phone without battery.
Old 12-29-2005, 00:35   #5 (permalink)
Member: 127049
okie with me
I click unlock and press power on button 1 second after that it work fine,( one second ) mean right away after click unlock
hope to help for NSBOX
Old 12-29-2005, 00:57   #6 (permalink)
Member: 105625
Hmm... the cable supplied with the box seems to be broken - when i use my old cable it workes fine.
Nokia N81 crashes when using certain features aminetm Nokia Hardware & Hardware-Repair Area 4 07-19-2009 12:11
error no card readers found when trying to use box mody 2 FuriouS TeaM Products 4 03-31-2008 17:04
Pls help me flash 5200 dead when unlocking with bb5 box hassan fode Nokia Hardware & Hardware-Repair Area 0 02-03-2008 15:25
NSDongle crashed while flashing. Now phone is dead, and can't be flashed. James_S NSPRO 6 02-19-2006 01:09
Page generated in 0.24381 seconds with 11 queries
