Nsdongle v3.8.0 test reports PLZ test Nsdongle v3.8.0 Agere flashing and post the results here. Nsdongle v3.8.0 work ONLY on Win 2000 and Win XP with minimum 128 Mb RAM |
Hi Elco Having a few problems with z500 is just wont connect i have had not problem on older versions |
for get that post above it works fine just a bad cable i had |
S410i phone not detected i have had not problem on older versions |
z140 error it worked in earlier versinos. now a window read out of memory z140 vodaphone spain. |
unable to flash d500 blinking with jaf, no problem to flash phone with serial cable, phone does not power on. |
problem also with serial cable, after flash (done without problem, just log stops to update, but progress worked), no way to repair phone, always restart with samsung logo. flashed with hwk without problem and phone is alive again. |
Having error during flash x480 with Nsdongle v3.8.0. |
PLZ download Nsdongle v3.8.1 and try again. |
3.8.0 Small Bug Hi, Could Not Be Able To Unlock E715 Phone. Tested Several Times But No Luck. So I Tested Version 3.8.1 Now And Phone Is Unlocked. For Your Info. |
1 Attachment(s) hi @Elco,the problem is not in your SW,U R using too new flashdll.dll( ver 4.16):cool: the flash loader for X480 is for older version(4.14) of flashdll.dll;) So paste ( replace )atached file in your NSDongle dir and all will work fine(tested with X480)!! BR PS: maybe some of other agere models will not work( flashing) but need to test this!!:rolleyes: PS2: remove .txt;) BR |
I didn have phone test yet but just have one question: Can we flash all agere models with normal flash(normal size) and full flash(big size) ? |
