11-01-2012, 12:08 | #1 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1655524 Status: Offline Thanks Meter: 0 | NSPro problems installing on Windows 7 Microsoft Usbccid Smartcard Reader (WDUF) But gives the error: This device cannot start. (code 10) When I try to force an e-gate driver the same error occurs or a code 39 error occurs, saying the driver is corrupt or missing. I've removed NS Pro software and reinstalled many times, tried alternative drivers, tried to find a generic driver but can't find 1. Any help would be much appreciated, the 'technical support' at FoneFunShop are useless. |
11-01-2012, 12:21 | #3 (permalink) | ||
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Isn't that 19 ? Last edited by Elco; 11-01-2012 at 12:27. | ||
11-01-2012, 23:53 | #8 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | I just checked on the internet... Luck's like Microsoft messed up something with the Jcop smartcard drivers on windows 7 update... So you have 2 options: 1. Remove the smartcard from NsPro box and connect it to a external card reader (ex. Pkey reader) so windows will use the reader drivers to access the smartcard 2. Use NsPro on win XP and install the drivers normally (Jcop drivers from NsPro Driver folder) |
11-02-2012, 00:50 | #9 (permalink) |
No Life Poster Join Date: Jun 2006 Location: JAMAICA
Member: 293299 Status: Offline Thanks Meter: 266 | hey Elco, I had the same problem with that WUDF driver and could Not get NSPRO to work,I had to format my laptop then turn off windows update then install NSPRO inorder to get it to work with windows 7. |
11-02-2012, 01:48 | #10 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Yes... i just saw on microsoft forums that windows dev team messed up with WUDF drivers on latest windows updates... Let's hope they will fix this problem soon. |
11-02-2012, 11:59 | #11 (permalink) |
Member: 1655524 Status: Offline Thanks Meter: 0 | Thanks for the update. I've started using it on another machine with XP, works fine on it. I wonder if it's possible, as a temp fix, to get a backup of the old driver from someone and force the reader to use that? |
11-02-2012, 12:03 | #12 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | The actual problem is not the driver files. Is the windows Smartcard Service that can't communicate with the card since updated to latest version. |
01-02-2013, 23:06 | #15 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | The Jcop incompatibility affect's only windows 7 x64 and windows 8 x64 versions. Windows x32 versions work just fine with Jcop smartcards. You can find the Jcop driver on NsPro Driver folder on your PC. |
