Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 01-03-2009, 18:07   #1 (permalink)
Member: 934255
Phone dead after flash
Hello, i need a urgent soluction for this.
After flash a j700 with nspro, the phone is dead. Dont have power.
I tried to flash but blue light on but get the information " Powering on mobile... Boot request error"
When i make service jobs and select all, nspro reset all exept wap reset.
The phone is dead whant could i do...
PLease help.
Old 01-05-2009, 05:09   #2 (permalink)
Member: 631286
download latest flash file ang try to flash
Old 01-05-2009, 20:45   #3 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Select J700 on NsPro.
Go to Flashing menu and select bin+TFS flashing mode.
Select flash files to be writed on the phone.
Click WRITE on NsPro software then connect the phone with battery to NsPro cable and press power on key on the phone.
If the flashing operation still dont start, then the phone may have a hardware problem.
Old 01-07-2009, 17:38   #4 (permalink)
Member: 934255
many tanks the phone is working now.
But have a problem that already have before.
Have full network but don't make any calls with any gsm network.
Already try to repair imei but the same.
If i try to make 10 calls shows the number dialing but dont have any information from other side.
Old 01-07-2009, 19:22   #5 (permalink)
brahmss's Avatar
Member: 621952
just check your imei, it may be on 00000000.... try to repair using the imei repair option, do it several times if it doesnt repair the imei. that may solve your problem
Old 01-08-2009, 12:15   #6 (permalink)
Member: 934255
Tanks for the help.
The imei is right, is the same on the back side of the phone.
But don't make calls anyway.
I now that is a software problem because this begins after flash the phone...
More solutions???
Old 01-08-2009, 12:27   #7 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Originally Posted by XPTO2511 View Post
Tanks for the help.
More solutions???
Try to write EEPROM ur problem will solve 100%.
Regards
Old 01-10-2009, 10:38   #8 (permalink)
Member: 934255
Hello,
I try to flash the phone, with the eeprom but not work.
When i write eeprom the imei of the phone change is normal?
Still can't make calls......
Old 01-10-2009, 10:49   #9 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
@XPTO2511
Reset ur phone by *2767*3855#/*2767*2878#.
if still had any problem check hardwere.
Old 01-14-2009, 17:09   #10 (permalink)
Member: 934255
Hello,
Try but is the same.
Is 100% software because before flashing the phone is good.
Old 01-16-2009, 12:01   #11 (permalink)
Member: 934255
no more solutions?????
Old 01-19-2009, 05:49   #12 (permalink)
amol_sm's Avatar
Member: 343326
Before flashing u r set is OK.......then why u flash the phone ?
Old 01-20-2009, 10:56   #13 (permalink)
Member: 934255
Before fash the phone sometimes loses network then i flash. Now dont make any calls....
Old 01-20-2009, 11:03   #14 (permalink)
Member: 934255
Old 01-30-2009, 12:42   #15 (permalink)
Member: 934255
I tink i now what is the problem.
I flash the phone with flash to j700 and mine is a j700G.
Where i can get this flash?????
7610 new flash chip phone dead after flash mccm Griffin 1 12-24-2005 08:21
6600 Phone Dead After Flashing!! Help Me mnmfaizal UFS2 + UFS3-Tornadoflasher 1 07-30-2005 05:45
phone dead after flashing... eadsign Samsung Flashers, Software, Firmware. 5 05-25-2004 19:46
Page generated in 0.32548 seconds with 11 queries
