02-09-2006, 14:01 | #1 (permalink) |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | Post here any problem with Nsdongle v3.11.6 all type of phone whene I presse flash it give me flash servise !!!! only when I wana for X640 (that I have death phone) the soft freez and close |
02-09-2006, 14:22 | #2 (permalink) |
Freak Poster Join Date: Oct 2000 Location: germany Age: 49
Member: 2321 Status: Offline Thanks Meter: 1 | LG U8290 canīt unlock hi i try so many times but cant unlock this one with NS dongle what ist the problem when i put the z500 kable in box and say some time usb kable was not reconized problem and some time go ok but after Unlocking...... geht the maessage operation Faild any solution Thx |
02-09-2006, 14:39 | #3 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 175297 Status: Offline Thanks Meter: 4 | NSDongle 3.11.5 Not working at all Some one more then me that have problems with the latest ver of NSDongle??? When i take x640 phone or some others i get error screen with WRONG PARAMETERS Please @Elco fix this bug, i have reinstalled several times and same all the time |
02-09-2006, 14:42 | #4 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | 1. Start the software 2. Select COM port 3. Select phone model If you dont select the com port, you get that error. I posted this in forum before. Just read the threads from this section. |
02-09-2006, 14:45 | #5 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Uninstall Nsdongle, download last version again, install it and try. | |
02-09-2006, 14:47 | #6 (permalink) | |
Try to use LG U8xxx USB cable. You also need to install LG USB drivers. Unlock for U8290 work correctly on last Nsdongle version: Nsdongle v3.11.6 | |
02-09-2006, 14:51 | #8 (permalink) |
Member: 2321 Status: Offline Thanks Meter: 1 | hi thx for help the usb driver i have already installed from the server hmm the usb cable from z500 ist not ok ??? i schould buy another cable for the LG ?? best regard |
02-09-2006, 14:55 | #9 (permalink) | |
That cable must work also... but you have the alternative. | |
02-09-2006, 14:56 | #10 (permalink) | |
No is not a bug. If you have Nsdongle Box, Nsdongle box will be displayed automatic.Com ports will available also with Nsdongle box. | |
02-09-2006, 15:32 | #12 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 191662 Status: Offline Thanks Meter: 2 | NSDongle 3.11.6 Not working at all I have installed and sucsessfully updated my dongle but every time i try and run NSDongle application....nothing happens?? I have tried unstalling and re-installing and restarting computer at all possible points.....still same problem? Dongle seems to connect to server ok.....as it has been updated to latest vertion i get following Diconnected from server Update Rejected: already updated 3.11.2 Connected to server |
02-09-2006, 15:40 | #13 (permalink) | |
02-09-2006, 15:41 | #14 (permalink) | |
PLZ set the correct time and date to your PC and check if dongle/box is correctly connected. | |
Post here any problem about Nokia keypad - key, and let me give you the solution | stefani | Nokia Repair Guide and FAQ | 850 | 08-22-2013 12:05 |
Hello....Post here any problem about Nokia | dharmdev | Nokia Hardware & Hardware Repair | 3 | 08-17-2013 06:07 |
bugs and things to do pls post here any problem on 1.28 | shoktong | MSS Box II | 1 | 12-08-2009 01:26 |
Update Problem with Nsdongle v3.12 | Irfangk786 | NSPRO | 1 | 05-02-2006 09:12 |
Nsdongle v3.11.6 released | Elco | NSPRO | 0 | 02-08-2006 14:27 |
