Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 11-29-2007, 17:10   #1 (permalink)
Member: 87998
problem with e250 from O2
i have 3pcs samsung e250 phone but they connect sometimes to nspro. sometimes i get all info and sometimes i just get sw version when i read info. i am not able to flash phones. wheni try other e250 from USA or other uk company i get full response. what is the problem?
Old 11-30-2007, 19:04   #2 (permalink)
Member: 87998
@elco
any help with this problem?
Old 12-16-2007, 18:31   #3 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
hi
i have this same type
and unlock 100% fine
but limited service after unlock
Old 12-16-2007, 19:14   #4 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Originally Posted by nasro_nd View Post
hi
Next time, make sure that you select correct phone model on NsPro: E250, E250D
You can see the phone version by typing code *#1234# or by using Get Info function on NsPro.
E250D phones are named like this: E250DXAGI4
If you try to unlock E250D as E250, the phone signal will be gone after unlock.
So make sure that you select correct model.
To fix a damaged phone, write eeprom ( you can find eeprom files on NsPro support area) then write back the original IMEI.
problem with e250 after flash with e250d realmadrid UST Pro II 6 02-17-2009 14:01
Problem with e250 sonkar UST Pro II 19 07-30-2008 05:56
problem with e250 riadd Samsung Flashers, Software, Firmware. 1 09-25-2007 13:21
i have problem with KG220 from O2 when i want to make it arabic tsarkh VygisToolbox 4 06-13-2007 10:04
Big Trouble with XDAII from O2!!! dedekwien HTC & PDA WM( With Touchscreen) 1 10-21-2005 13:14
Page generated in 0.44023 seconds with 11 queries
