Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 09-20-2008, 00:06   #1 (permalink)
rx7
Member: 85949
Unhappy Problem unlocking j600e!!!
I am trying to unlock J600e I spent days on it, when I do unlock or get info I get this message
Waiting for Phone...
Entering Test mode...
MSL Security Detected!!!
Calculating MSL...
Operation failed!
I am using 4.3.1 version
I also tried to flash the phone but same problem!!!
PLEASE HELP ME!!! I really need to unlock these j600e `s
Old 09-20-2008, 00:19   #2 (permalink)
Haicha's Avatar
Member: 330579
Sonork: 100.1620425
Hello
Calculating MSL...
Operation failed!
Friend!
If you can try this codes:
The method:
Power on phone.
Keep phone on and insert incorrect sim card (here you still have "insert sim card" on the screen)
Make a E2P reset *2767*3855#.
Phone reboot and you must have your card accepted now.
After that *7465625*638*00000000*00000000#
For finishing #7465625*638*00000000#
Haicha
Old 09-21-2008, 15:31   #3 (permalink)
rx7
Member: 85949
Unhappy
I tried with those codes but no luck I thought that is not going to work with just codes!!!!! not that easy, PLEASE SOME HELP!!!
Old 09-21-2008, 15:51   #4 (permalink)
Registered User
Member: 811992
Sonork: 100.1584257
Hello
Thus with LV pro you can unlocken Samsung SGH J600e, but you also the correct cable for it took? It shows on however it can be which you perhaps another took, you must the D800 cable take, afterwards mobile phone on switch and somewhat clean-push the cable, but komplet, then you press clean-pushed UNLOCK dan the remainder of the cables to put in correctly immediately, afterwards that would have to function!
Greeting Service4Gsm.de Team
Old 09-24-2008, 23:39   #5 (permalink)
rx7
Member: 85949
I tried everything but nothing, I think not supported yet !!!!!
Old 09-28-2008, 23:41   #6 (permalink)
rx7
Member: 85949
OK problem solved after days working on it
Old 09-30-2008, 00:16   #7 (permalink)
Professional's Avatar
Member: 362955
Would you please share with us how u unlocked ur j600E.
Old 09-30-2008, 00:19   #8 (permalink)
Member: 362955
while using latest version I unable to unlock J600E .
when i go unlock or get info, the process gets to "Calculating MSL" the process then fails, every time this happens i noticed the phone turns off then turns on like a quick restart, the phone then appears with "please wait..." then its back to the state it was before unlock.
I know it can be unlocked by flashing but if there is a direct unlock solution that would be great.
Professional
can i unlock j600e using ust pro ruvanw1979 UST Pro II 2 02-11-2010 07:35
help to unlock j600e izamer UST Pro II 4 06-19-2009 11:28
USTPro Fails to Unlock J600e.. GSMcracker UST Pro II 2 03-19-2009 12:09
polar cant unlock j600e? :::ANSWERED::: lusandi PolarBox 2 1 12-16-2008 19:28
Help cannot unlock j600e AbdulKadir NSPRO 3 09-17-2008 21:39
Page generated in 0.27627 seconds with 11 queries
