10-24-2005, 05:56 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Cebu, Philippines
Member: 15652 Status: Offline Thanks Meter: 344 | PROBLEM w/ SUPPORT due to INTERNET GATEWAY CONFIG REASON: MULTIPLE IP. I have written to support site several times already to understand the situation but SUPPORT has DEAF ears. Having MULTIPLE IP is not the only criterion of SHARING of LOGIN as i will explain later. The multiple IP login was unintentional and unavoidable in my end as my connection are passing thru a router with multiple gateways from different ISP which does autobalancing and redunduncy. IT is only NS DONGLE SUPPORT that i am having problem with as i own more than 10 original boxes. SUGGESTION TO NS DONGLE: As i explained i have multiple IP addresses assign randomly from my router, but checking thru multiple IP criterion is insufficient for you to determine that there are more than one users with same login credential logging to your site, THUS BANNING the USER. Consider to add the COOKIES, the SESSION ID and the IP ADDRESSES to monitor IF there is MULTIPLE login using with the SAME account. Example, if i have 2 IP addresses, but the SESSION ID is only 1, does this mean that there is multiple user log on?????????????? YOUR RESPONSE TO THIS MATTER IS HIGHLY APPRECIATED. Last edited by livewirecebu; 10-24-2005 at 10:01. |
10-24-2005, 09:26 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Exactly the same problem with me, but now my ISP has assigned static IP address for me, so problems are away now. But this NSdongle policy is really strange. |
10-24-2005, 10:04 | #3 (permalink) |
Member: 15652 Status: Offline Thanks Meter: 344 | my situation is not exactly a problem of a dynamic IP. Dynamic IP means you will have 1 randomly assigned IP everytime you connect to the net. My situation is i have multiple IP connected at the same time and my LAN router chooses which connection have least traffic (autobalancing feature) because we have several PCs connected to this network. |
Format my dongle due to space problem | rajan nishchal | FuriousGold | 2 | 02-08-2010 08:03 |
5300b unlocking problem due to someone upgrade the phone | SHANU | BB5BOX | 2 | 11-03-2007 18:41 |
D500 speaker problems, is it due to flashing? | solid_snake | SWIFT Platform | 0 | 10-17-2005 17:20 |
3310,no signal due to a software problem, | alrbee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-03-2002 22:07 |
