11-05-2009, 22:13 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | s5600 after unlock cant make calls... |
11-06-2009, 01:05 | #3 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
You unlocked and reflashed ok. But unfortunately the fw you've wrote isn't good. Just use another flash file, suitable to your country/network settings BR Max_B | |
11-07-2009, 08:26 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | If U Want To Flash Than Use This FW S5600_Firmware_OK_for_Unlock.zip Download From Support Sure U Will Never Face The Signal Problem Tested Regards UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
11-07-2009, 22:00 | #13 (permalink) | |
I'm sure you tested ! But "where" did you tested this my friend ? Did you in UK ? In France S5600_Firmware_OK_for_Unlock has signal but don't receive calls, what do you think now ? Ok all firmwares don't support all European network settings ! In other words I mean each service provider is not equiped with the same hardware and software and technology. I mean between the MS and the BTS ! hehe, BTS has several firmware updates too eg. ORANGE has definately different ones ! That's why since a long while ago, many (not branded) firmwares versions are only build for Orange. But you cannot experience that since your countries still uses old generation stuff. Don't worry new network hardware will come to your countries soon enough, so you'll be ahead to fix such firmware issues BR Max_B Last edited by Max_B; 11-07-2009 at 22:05. | |
11-08-2009, 04:01 | #14 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | brother any it wont supports i agree but also itmay work as it worked on me as i write nvm also firstly try with unlock firmware which is given in supportif its wont work then try but i can do that problem easily here we recieve world wide network provider. |
11-08-2009, 05:30 | #15 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | @max B S5600_Firmware_OK_for_Unlock This files works Fine for Most fo the Countries Worldwide..Still Few Specific Issues u r Rite...But am Doubt about HOw this Works...Still Curious to Know Network Based Fw Signal Issue ETC.. Thx |
ku990 after unlock cant make call | waqas_ali601200 | Z3X-Team Products | 6 | 02-22-2010 09:47 |
w660i after unlock ,can't make call | waleedy | Sony Ericsson | 1 | 06-26-2008 06:47 |
Z240E after unlock cant make calls | cocoliso2005 | Easy-Unlocker | 6 | 04-22-2008 11:22 |
Z520i after flash cant make call to zula | morteza-icu | SonyEricsson (USB-Smart) | 3 | 04-15-2006 14:39 |
511-512 after unlock not make calls!! | conti | BF, BG, TH, BHx Series | 5 | 10-12-2003 01:51 |
