11-10-2013, 07:08 | #16 (permalink) |
Freak Poster Join Date: Sep 2012 Location: USA
Member: 1809913 Status: Offline Thanks Meter: 35 | |
01-24-2014, 21:49 | #17 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Honolulu Hawaii
Member: 2091124 Status: Offline Thanks Meter: 15 | I get access denied using NV CDMA items writer it was mentioned a few posts back does anyone have a work around If I root and disable Knox?? Sent from my Nexus 5 using Tapatalk Last edited by androidhawaii; 01-24-2014 at 21:56. |
01-29-2014, 06:27 | #19 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2116621 Status: Offline Thanks Meter: 0 | Any get this working? I was thinking of picking up a note 3... And am always like flashing roms. Imei repair should be figured out now that I hone has been out for a few months. |
02-01-2014, 01:37 | #20 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Its more than a simple IMEI repair and a modem patch etc ... Method will not be released for many reasons .... Hopefully the creators from Nspro,z3x,Ocotpus box release something for it .. until it wont be released .... |
02-02-2014, 01:03 | #22 (permalink) |
Member: 2110016 Status: Offline Thanks Meter: 4 | jusmejose, I've read a lot of your posts on this and other forums and I admire your altruism... but could you please give some more details about why you won't say how to write it; is it an exploit of android's handling of the nvdata partition? If so that would be quite a find, and I would understand why nobody would be willing to share that. I feel like Alice in Wonderland after everything I've read on this topic, from QC chips in Blackberrys years ago, to the modern method mostly used for changing CDMA networks. To anyone interested, here are some tidbits of what I've stumbled upon: pastebin.com/jewTddnc There is countless more info that I've read, but those were the most on point I would say... good luck going down that rabbit hole, or black hole I should say, as it's fun to learn about, but your time will get sucked in. P.S. I'm "researching" this for an n900a which the bootloader is locked on. It makes experimenting with the AT commands a tiny bit more difficult... I hope that either Knox is exploited, or that Samsung is so proud of Knox that they throw consumers a bone by undermining AT&T and releasing the key... both of which are unlikely anytime soon. P.S.S. I very much respect the NSPRO team, so if there is anything in this post that is not acceptable, please snip it out. |
The Following User Says Thank You to FlankYou For This Useful Post: |
02-02-2014, 19:27 | #23 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Toronto Age: 41
Member: 84323 Status: Offline Thanks Meter: 15 | If you root, upgrade SuperSU, that will take care of KNOX and that gets disabled in the process. It probably has to do with how the efs nv stuff (not a programming genius as you can probably tell) is written on the chip. |
02-21-2014, 02:35 | #25 (permalink) | |
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
02-22-2014, 00:19 | #27 (permalink) |
Member: 1081371 Status: Offline Thanks Meter: 720 | JTAG repair thats all... for many reasons it hasent been release for public etc ... Thats why only certain people are able to do it ( I guess for the files etc)... at this point only that i know probably 8-10 people are able to do it in the United States ... |
02-28-2014, 07:37 | #30 (permalink) |
Member: 84323 Status: Offline Thanks Meter: 15 | Playing with the NV gave me some insight. We can easily change the IMEI bit on the N900x series... but since some of the NV bits are protected we cannot write the IMEI entirely. The N900x series performs some type of verification or check and compares IMEI, if there is a mismatch, the IMEI CERT Fails thus you cannot connect onto the network although the IMEI has been "repaired". Key in my opinion is to bypass the protected NV items and pretty much "copy and paste" a "good" nv onto the device. This "MAY" be done via Jtag. |
