sm-g313ml claro unlock problems I have a G313ml with claro el salvador on android 4.4.2 which I rooted than unlocked with NSPro except that out of 4 possible networks it only shows and is unlocked for 2 of those networks with 2G only as it no longer detects 3G networks. repaired IMEI, still the same, did a hard reset still the same, downloading the firmware to see if that has any effect. Any help or suggestions would be greatly appreciated. |
pls help me how to root this phone g313ml 4.4.2. br sunnny |
Sunny I used this page to root and it seems fine but becareful because I don't know if thats what caused my problem which i still have not fixed. |
Guess I will hold on to this phone till next month when my Z3X arrives and ask for help on that forum. |
i got the same handset with the same problem im searching for cert file..... all ready fix imei, path cert flash with latest update with same result |
Nothing ever worked for me even after flashing the cert. My guess is that the NSpro screwed something up as I have unlocked many of the same models with z3x and never had a problem. |
your right. Im still stuck with this problem i should read codes or unlock with z3x but didnt knew anything about this. What i noticed is that NSPRO support SM-G313ML but the duos version because when you try to repair imei you have to fill both imei tabs |
Noticed that as well but I didn't think it was that important, I really wouldn't waste too much time on it, I spent months with it till I finally solid it as is with only 2G working for Claro El Salvador. |
