02-05-2015, 06:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: the moon
Member: 1740779 Status: Offline Thanks Meter: 143 | sm-g313ml claro unlock problems |
02-05-2015, 16:24 | #3 (permalink) |
Member: 1740779 Status: Offline Thanks Meter: 143 | Sunny I used this page to root and it seems fine but becareful because I don't know if thats what caused my problem which i still have not fixed. |
02-18-2016, 23:41 | #5 (permalink) |
Freak Poster Join Date: May 2007 Location: Nic@r@gu@ Age: 41
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | i got the same handset with the same problem im searching for cert file..... all ready fix imei, path cert flash with latest update with same result |
02-18-2016, 23:56 | #6 (permalink) |
Member: 1740779 Status: Offline Thanks Meter: 143 | Nothing ever worked for me even after flashing the cert. My guess is that the NSpro screwed something up as I have unlocked many of the same models with z3x and never had a problem. |
02-20-2016, 17:50 | #7 (permalink) |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | your right. Im still stuck with this problem i should read codes or unlock with z3x but didnt knew anything about this. What i noticed is that NSPRO support SM-G313ML but the duos version because when you try to repair imei you have to fill both imei tabs |
02-20-2016, 18:14 | #8 (permalink) |
Member: 1740779 Status: Offline Thanks Meter: 143 | Noticed that as well but I didn't think it was that important, I really wouldn't waste too much time on it, I spent months with it till I finally solid it as is with only 2G working for Claro El Salvador. |
