03-28-2009, 05:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: New Zealand
Member: 612635 Status: Offline Thanks Meter: 194 | Softbank 707SCII unlocking problems I have a Softbank 707SCII in front of me - 2008. 03 "Download 1.3" "Chairman 2" Everytime i try to write the unlock file to the phone, i get "Reading file acknowledge failed! Writing NsPro file Proceeding with file... Press NEXT to continue..." Ive reinstalled NsPro, reinstalled the drivers - even tried different versions of NsPro. Also my cable is working fine - I can unlock/read other phones that use the D800 cable. But cant see to get the phone unlocked! NS pro port is detected on COM5. The phone is connecting as "Samsung modem CDMA #2" when i hold down 9+on button. Some please help me get this phone unlocked! Thanks |
03-28-2009, 11:34 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Use 707SCII 2008 Patch For Unlock on that phone and the phone will be unlocked. |
The Following 2 Users Say Thank You to Elco For This Useful Post: |
03-28-2009, 22:47 | #4 (permalink) |
Member: 612635 Status: Offline Thanks Meter: 194 | I just installed NS Pro on another computer and tried to unlock the phone, same result - Using 707SCII 2008 Patch For Unlock.nqf Are you meant to plug in the phone first, then boot it to the bootmode? - When I plug in the phone, it turns on, and starts charging, and when you press 9+power it does not go into boot mode - However when i put the phone into boot mode first it comes up with the "Download 1.3 etc" then gives me the error as above Please help |
03-28-2009, 23:08 | #5 (permalink) | |
Member: 612635 Status: Offline Thanks Meter: 194 | And ive done exactly this.... Quote:
03-29-2009, 12:17 | #7 (permalink) |
Member: 612635 Status: Offline Thanks Meter: 194 | Problem solved Since it didnt work on another computer, i checked the file "707SCII 2008 Patch For Unlock.nqf" For some reason, the computer or NS Pro, had made the file to be only 10MB - Anyways, I still had the zip file, so extracted that from the zip file, and applied the patch and it worked first time! So anyone getting "Reading file acknowledge failed! Writing NsPro file Proceeding with file... Press NEXT to continue..." Few things to check for -Reinstall NS-Pro -Check cable -Check unlock file size (ie should be 38mb's or so) Phone unlocked 100% BR |
SoftBank 707SCII unlock??? | dragosgsm | NSPRO | 9 | 09-16-2010 08:37 |
softbank 707scII unlock patch unlock done | omer100 | NSPRO | 3 | 12-07-2008 17:29 |
softbank 707SCII unlock but cant call/sms in | ascdf13 | YESSIM | 2 | 08-13-2008 00:04 |
Softbank 707scii Unlock Easy? | GUDO-GSM | Easy-Unlocker | 3 | 11-09-2007 10:53 |
