Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 09-11-2012, 19:39   #1 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
Thumbs up Successfuly Repair Imei SIII I9300
Wow Nspro Tem bOM bOM UPDATE
The Following 4 Users Say Thank You to bux_harun For This Useful Post:
Old 09-11-2012, 20:12   #2 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,167
wahooo nic working bro
NSPRO good tool
Old 09-11-2012, 22:25   #3 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
Thumbs up Repair Imei SIII I9300 2nd phone With Prof
Hay I M Repair 2nd Phone With Prof
Nice work NS Pro
Preparing Phone...
Resetting IMEI...
Connecting to phone UART...
Reading MSL...
Using Advanced MSL...
Bypasing Security...
Writing IMEI...
Resetting Phone...
Operation successfully completed
Old 09-12-2012, 16:28   #4 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 438
Hi, I got same work to do tomorrow, if activation of box is done, so I have few questions if you don't mind :
what cable did you use ?
how did you flash patch file ?
is there specific step I should know to not waste most time ?
Thank you, BR
Old 09-12-2012, 18:06   #5 (permalink)
Member: 1809822
Thanks Meter: 10
What tool do I need for the fix, killed customers device and need to fix
Imei = NaN, will nspro save the day?
Old 09-13-2012, 03:21   #6 (permalink)
Member: 1809822
Thanks Meter: 10
Does it solve no EFS partition problem?
In my case it won't even restore backup image I had with efspro
Old 09-13-2012, 09:37   #7 (permalink)
Member: 1791766
Thanks Meter: 2
The i9300 patch with Jelly Bean XXDLI5 firmware ?
Old 09-13-2012, 10:16   #8 (permalink)
Member: 1107355
After imei repair, can we flash or update the original software without losing the network, anyone tried..?
Thank you.
Old 09-13-2012, 10:59   #9 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
Arrow
Thank you.
Hay Bro
I M Repair IMEI and After Update Phone Online No Problem N successfully
Update
The Following 2 Users Say Thank You to bux_harun For This Useful Post:
Old 09-13-2012, 19:15   #10 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
Originally Posted by bux_harun View Post
Hay Bro
Update
r u sure after updating u didn loose network. ???????????
Old 09-15-2012, 00:15   #11 (permalink)
bux_harun's Avatar
Member: 1638915
Thanks Meter: 411
Arrow Hay Bro
Hay Bro I M sure 100% Not network Lose I m All Rady Use handset
Old 09-16-2012, 18:36   #12 (permalink)
Member: 619308
Sonork: 100.1591829
Thanks Meter: 243
if u change imei and after that update firmware and dont loose network.then nespro first in the world. there is no box sport not loose network after update firmware.
Old 09-17-2012, 11:54   #13 (permalink)
Member: 1777637
Sonork: 100.1616860:md
Thanks Meter: 32
can i use any samsung imei for change imei i9300? or anything else? please help me. thanks
Old 09-28-2012, 14:17   #14 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 259
Preparing Phone...
Resetting IMEI...
Setting Serial Number...
Writing IMEI...
Resetting Phone...
Operacao com sucesso concluida
Old 09-28-2012, 18:24   #15 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,391
Better use I9300 Root file from NsPro support area to root the phone
Then select "I9300 Rooted" on Nspro to perform IMEI Write operation.
The Following 6 Users Say Thank You to Elco For This Useful Post:
Page generated in 0.55415 seconds with 8 queries
