10-20-2012, 09:44 | #46 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 659 | Resetting IMEI... Connecting to phone UART... Using Advanced MSL... Bypasing Security... Setting Serial Number... Writing IMEI... Resetting Phone... Operation successfully completed Yes tested working on rooted phone. |
10-20-2012, 12:28 | #48 (permalink) |
Freak Poster Join Date: May 2007 Location: Buenos Aires, Argentina
Member: 515637 Status: Offline Thanks Meter: 13 | Hi, i need repair imei damage, 004999..... Resisto in cable is 560 k or 130 k,,tnk in advance http://www.subirimagenes.net/show-im...af376fc4632d40 Last edited by otrebor2; 10-20-2012 at 12:37. |
10-20-2012, 16:50 | #50 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 567 | Quote:
By ELCO (just make sure you are using NsPro S7070 cable and will work just fine) Tested Many time br Polaco Last edited by el-polaco; 10-20-2012 at 16:57. | |
10-20-2012, 23:07 | #51 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 14047 Status: Offline Thanks Meter: 166 | Quote:
10-22-2012, 11:48 | #52 (permalink) |
Member: 14047 Status: Offline Thanks Meter: 166 | i9300 cable correct wired ? hi i bought this cable from completefonesolution can anyone tell me if it is correctly wired as uart for imei repair i9300 ............and can tell me correct way if its not thanks ................................................br |
10-22-2012, 16:39 | #53 (permalink) | |
i flashed my phone with flash from support dont know if i needed to but i did i rooted the phone with rooted file form support i keyed in *#7284# top one is put uart modem bottom one i left usb pda i conected to nspro and wrote original imei and original serial when it asked uart i conected and all is good the cable i bought from above was perfect so if your in the uk get it hope this helps anyone else trying to fix this problem........................................... ..br | |
The Following User Says Thank You to simlock For This Useful Post: |
10-23-2012, 12:40 | #54 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | Quote:
11-04-2012, 15:16 | #56 (permalink) | |
http://forum.gsmhosting.com/vbb/f475...added-1561052/ br polaco | |
11-04-2012, 18:12 | #57 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | The patch was removed because is incompatible with latest i9300 firmware versions. You must use Root file instead. About please READ!!! the message on the top of Support area page: |
11-13-2012, 16:35 | #58 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | hi elco, need your help.. i have fixed my i9300 imei (which was damaged 004456) now imei is good sn number is also ok but there is no network need urgent help.. |
11-13-2012, 16:50 | #59 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
2. Root the phone with root file from NsPro support area 3. Write IMEI again using NsPro v6.5.1 After writing IMEI by NsPro, the phone network will be OK If still no network after IMEI write by NsPro, check the phone for hardware problems. Next time when you post about a problem with Nspro, plz post a screenshot with Nspro software operation so i can see what chould be the problem. IMEi write is tested and 100% working on NsPro. Also the phone network is OK after IMEI write: | |
11-23-2012, 20:00 | #60 (permalink) |
Freak Poster Join Date: Jan 2010 Location: ScBraga-Portugal
Member: 1218089 Status: Offline Sonork: 100.1615672 Thanks Meter: 8 | in my case, i can only repair the serial number, the imei stills 00499901... and i have network but when i call to my s3 from other phone, i cant reach it. |
