06-23-2007, 18:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Berkane to netherland Age: 48
Member: 58969 Status: Offline Thanks Meter: 56 | U600 after enter 3 times the code totaly lock closed U600 after enter 3 times the code totaly lock closed how can i solved this probleme |
06-23-2007, 22:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Connect the phone powered on to NsPro and use UNLOCK function. Phone will be unlocked in few seconds. If the phone is showing "Phone licked return for servicing" then there is no solution for that problem yet . Last edited by Elco; 06-24-2007 at 17:50. |
06-24-2007, 12:16 | #3 (permalink) |
Freak Poster Join Date: Jan 2004 Location: netherlands Age: 42
Member: 50272 Status: Offline Thanks Meter: 37 | you cant fix after unlock. because your tested version is not supported yet by ns pro. u can fix only by unlock with any other solution which support new version u600 by direct unlock. u can wait for update for ns pro if this version added than only direct unlock. b.r Secgsm |
06-24-2007, 17:30 | #4 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Dont forget that NSPRO ALLWAYS GIVE YOU THE REAL and TESTED SOLUTIONS Just luck at the last version. Competition jumped to copy solutions from NsPro. Examples: 1. U600, E420, E480, E390, E690, T329 (NsPro v2.4.0) 2. X540 (v3.0.0) 3. D900i, E200, E830, Z240 (v3.1.0) and the examples can continue. pity that they not even copyed correctly... and models like E420, E480, E690, Z240, etc... cant be unlocked with "other solution" So... dont worry. If the phone cant be repaired with NsPro, cant be repaired with "other solution" And now you know the reason why. I am talking about REAL solutions. Not about adding the phone into the software list and "hoping" that will work or "hoping" that peoples will not notice that the software was never tested with that software. Last edited by Elco; 06-24-2007 at 17:40. | |
Ho to repair U600 . After flash always time freeze in start up :( | e-gsmshop | NSPRO | 6 | 02-28-2009 19:51 |
Enter 3 times same imei | americantel | A1-Services.org | 8 | 12-05-2008 20:55 |
Who to reset BB5 After enter 5 times a Wrong Nck !! | flechazo | Universalbox | 7 | 10-03-2006 23:33 |
Wich prog. open the T630 4 locks closed | senor | Sony Ericsson | 5 | 02-21-2004 10:45 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
