02-12-2013, 23:41 | #1 (permalink) |
Freak Poster Join Date: May 2001
Member: 4527 Status: Offline Thanks Meter: 40 | Which version of NsPro I can use? In Nspro support sticky I found that "NsPro server will allow inactive inactive NsPro cards to run any NsPro version released before activation expiration date" My nspro seems expired later than v6.5.4 showed up but I can't use it. Moreover I can't use any older version I've paid for. In sticky also written: "If your card is inactive and you cant access the support area, use this version to access the support area: : : NsPro v5.2.3" but given link is not working. Found v5.2.3 on another PC. But when running it I get same "use latest nspro version" So which version now I can use to access support area and which version I can use if my activation expired few weeks ago? How to find out exact expiration date? regards |
02-13-2013, 00:13 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: JAMAICA
Member: 293299 Status: Offline Thanks Meter: 266 | 1.search the forum for the link to 5.2.3 Elco already post it. 2.you should be able to use the last version you had active so contact Elco in private message with your serial so he can check your status on the server. 3.http://forum.gsmhosting.com/vbb/f286...dated-1235221/ |
02-13-2013, 00:21 | #3 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
BTW! You can allways check on NsPro when your activation expire: | |
02-13-2013, 12:09 | #4 (permalink) |
Member: 4527 Status: Offline Thanks Meter: 40 | ok. Today v5.2.3 is working. Although it not show when my activation expired. So, I'm PMing my Nspro SN to Elco. Also today "Nspro v6.5.4 small.exe" after installing and running say "NsPro detected that you are using an older version of application... Do you want to continue without installing the new NsPro version?". If I press "Yes" then I get "Please use latest NsPro version". I'm sure that "Nspro v6.5.4 small.exe" was working for me on 2012/12/28 and my activation was not expired. Today even v6.5.2 not working. What could be wrong that I can't use older version which was working before? regards |
02-13-2013, 14:17 | #5 (permalink) | |
So your activation expired on 29.09.2010 | |
02-13-2013, 21:07 | #7 (permalink) | |
NsPro smartcard connect from time to time to server to check the activation status. When the card connected to server and detected that your activation expired, it asked you for new activation. | |
02-14-2013, 12:13 | #9 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Is not about how old it is... Is about that was released AFTER that version, so you know what you are missing: Let's see: NsPro v6.5.5: -Added I8190 Galaxy S3 Mini Super Fast DIRECT Unlock No more flash, root, etc... 3 Seconds DIRECT Unlock NsPro v6.5.6: -Added I747, T999 IMEI repair - First In The World!!! -Added i9100 Android 4.1.2 Direct Unlock support - No Root Required! - First In The World!!! -Added I9305, N7105, T889, I317, S5360, S5363, S5369, B5510, S5570i, S5830i, S5839i IMEI repair -Added Relock to Network function for several models (ex. i9300, i9100, i9250, etc...) NsPro v6.5.7: -Added i747, T999, T889, i317, i9305, N7105 Repair 3G/4G connectivity on IMEI repair procedure. -Fixed minor software bugs. NsPro v6.5.8: -Added I9105P Galaxy S2 Plus FULL SUPPORT - FIRST IN THE WORLD!!! -Improved T989, T989D, I727 IMEI repair. -Improved various Android functions. |
The Following 2 Users Say Thank You to Elco For This Useful Post: |
02-15-2013, 09:58 | #11 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | That is life maybe bug on server and you serial got info that is activated right now is fixed. If want use spt just use 5.2.3 if want new on just buy activation 25 euro is no so much money per year. |
06-20-2015, 11:40 | #12 (permalink) |
Insane Poster Join Date: Jul 2012 Location: cambodia
Member: 1781372 Status: Offline Thanks Meter: 1 | Hi Elco now i want to activate my nspro box ........ and i want to know How many years that can i Use Nspro box after activated ,,,,,,? thankssssssssssssssssssssssss |
06-22-2015, 12:57 | #13 (permalink) |
Insane Poster Join Date: Mar 2006
Member: 252293 Status: Offline Thanks Meter: 16 | Just use crack and you can use it forever. Don't look for Elco anymore, he is stock in his cave for long time already. Just move on, there is plenty of useful box in the market with the same price such as BST tool. Nspro was the box used during the century of the dinosaurs. |
07-15-2015, 10:06 | #15 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Romānia
Member: 76629 Status: Offline Thanks Meter: 76 | NsPro old versions You can use version 6.7.2 without new activation. Must install 6.7.0 full installer, after that install 6.7.2 small installer. That can be downloaded from here. |
