Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 01-16-2006, 16:46   #1 (permalink)
Member: 205029
z500 and dongle box.
I have z500 to unlock and i cann't install z500 drivers into dongle as the box and PC is not reconizing the new hardware.Con i install without being reconized so i can work on the phone thanks.
Old 01-16-2006, 17:02   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Connect powered off phone to cable. Phone will power on. Start nsdongle v3.10.8 and select Z500 . Then install drivers.
Old 01-16-2006, 17:32   #3 (permalink)
Member: 205029
Z500 unlocking
Hi there i've tried this and its not letting me install driver for z500
Old 01-16-2006, 17:35   #4 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
PLZ explain. What happend? You use Nsdongle Box?
You use Nsdongle v3.10.8 ?
Phone have powered on when you connected to cable?
Have you selected Z500 on Nsdongle before installing driver?
Do you use Zxxx USB driver from support zone?
Old 01-16-2006, 17:45   #5 (permalink)
Member: 205029
Z500 unlocking
Hi there yes dongle box 3.10.8 have downloaded z500 zip to desktop.Z500 off plug in z500 cable open dongle box select z500 and nothing tried to enter z500 driver though device manager but it cannt find z500 drivers even though i select not manual.
Old 01-16-2006, 18:16   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
PLZ read my post again. Step by Step.
Old 01-16-2006, 18:52   #7 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
@ mr elco
i changed imei on z500 with new (ns dongle box) but the bluetooth stoped working after that need help please
please reply
thanx
Old 01-16-2006, 18:56   #8 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Originally Posted by rajinder
@ mr elco
please reply
thanx
Have you tested bluetooth before writing IMEI? PLZ explain me what happend? BLuetooth cant be activated? or cant connect with other devices?
Old 01-16-2006, 19:02   #9 (permalink)
Member: 205029
z500 unlocking
Hi there Elco I have done all this downloaded zxxx file from support center.Pluged in phone not swithed on select z500 and try to install.I look in device manager and see samsung CDMA TECHNOLIGIES and install drivers but it keep saying drivers can not be found and hardware has not install properly and may not work.Try to update and the same happens.
Old 01-16-2006, 19:10   #10 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Use Nsdongle Box and Z500 RJ45 cable for Nsdongle Box.
1. Connect powered off phone to cable (phone must be with battery). Phone will power on by himself (if you use correct cable)
2.Start Nsdongle v3.10.8
3. Press Suport Area button and go to support zone, download Zxxx USB drivers. Unzip and install drivers.
4. Select Z500 on Nsdongle software.
5.Windows will detect new device. Select to install drivers for new device from folder where you have unpacked the Zxxx USB drivers.
After installation is comlete, use UNLOCK button from Nsdongle to unlock that phone.
Is that hard to install some drivers?
Old 01-16-2006, 19:17   #11 (permalink)
cellularman's Avatar
Member: 150246
if i use Z500 RJ45 cable why to install drivers ? the phone connect to the NSBOX and not to PC-USB PORT ... ???
Old 01-16-2006, 21:03   #12 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Phone connect on UART mode to Nsbox and connect on USB mode to PC trugh Nsbox. So the drivers are still needed for USB connection.
Old 01-16-2006, 21:43   #13 (permalink)
Member: 150246
ok got ya man...thanks
Old 01-16-2006, 22:11   #14 (permalink)
Member: 205029
Z500 unlocking
Elco sorry mate what ever i try i cann't get the software to work.Have done as exactly as you say but cann't install the hardware ,kept on trying and got there in the end On windows XP and had to disable firewall .Thanks for your help.
Old 01-17-2006, 11:05   #15 (permalink)
Member: 7977
z500 connect rj scheme box
Please scheme for connect z500 to rj nsdongle box usb cable not rebuild imei
thanks
Boxes and dongles are the past and server software the future reactos Sony Ericsson 27 01-27-2011 15:33
t-box dongle picture and t-box pcb picture need somonahmed T-BOX Products 1 03-17-2010 15:42
BOXES AND DONGLES..anyone pls. hitech3 NEC 1 02-25-2005 07:49
UFS3 AND GRIFFIN BOX,and all new dongles stock in india shaikhboy Main Sales Section 0 01-29-2005 07:34
Page generated in 0.39492 seconds with 11 queries
