Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Remote Universalbox Team
Old 08-28-2005, 19:05   #1 (permalink)
Member: 847
d750-k750 serial cable
Hi, im using serail cable for k700 etc.
What pinout can i use to put a d750 connetcot to t28 serial cable?
or only usb possible?
I want too out a k750 connecter to t28 serial cable,
On t28 cable 4 wires connected.
thanks
Sjakie
Old 09-23-2005, 09:41   #2 (permalink)
Member: 183390
sir
I think its is not possible since the k750 runs only on usb . have u try the setools its good sir
Old 09-24-2005, 09:38   #3 (permalink)
Member: 847
Hi, solder a 750 too siemens usb cable, workimg fine with logs.
But cannot work with UFS setool card combination?
regadrs
Sjakie
Old 12-14-2005, 12:06   #4 (permalink)
csarlee's Avatar
Member: 25131
regadrs
Sjakie
Hi,
Can you tell me how to build a K750 cable from a Siemens USB cable? I have been hunting for it for months....
Regards,
Csarlee
Old 01-12-2006, 14:36   #5 (permalink)
Member: 219055
Talking
Originally Posted by csarlee
Hi,
Regards,
Csarlee
Just a short note if it helps. I use TotalMultiserver to unlock / repairs SE's if totally necessary. I never had a USB cable for K750 but I have the USB to COM cable which I use for my NSDongle Software.
I have a ps2 connector which I use to unlock K750 via my SuperClip and to connect the K750 to pc I simply use this ps2 connector with my USB to COM cable. And it does work a treat.
Its also works with my serial cable which I use for my Vygis (LG Unlocking Software).
So at the end of the day, there is no need to buy a special cable for the K750 as long as you have a ps2 connector for it, which most unlockers should treasure as a prize possession lol.
Old 01-12-2006, 20:10   #6 (permalink)
csarlee's Avatar
Member: 25131
It is okay you have a PS2 connector, but the root cause of this is inside the cable. My original problem was that I had a T28 cheap/china whatever service cable which had only 4 wires to go to the phone. Then I asked around about how to build a SERIAL cable for new SE phones and those schemas I got here haven't worked at all. Now I figured out that my T28 cable utilizes a 5 V technology because it is based on Max232 IC, so I gonna build a 3,3 V based multi interface and try with that one...
Csarlee
k750 serial cable dejoo Sony Ericsson 1 06-27-2007 21:37
k750 serial cable dejoo Sony Ericsson 0 12-11-2006 08:49
How to repair D750 / K750 / W800 Bluetooth Problems with HWK ? MisterX GSMFREE HWK 6 02-20-2006 15:47
any one tested d750/k750 flash? aznpdaddy SonyEricsson (USB-Smart) 1 08-11-2005 19:03
D750/K750 original cable credits! Salami1_1 Main Sales Section 0 06-20-2005 15:20
Page generated in 0.28179 seconds with 11 queries
