x100,x200,x300,x400,x500 flash procedure!! Hi ALL. 1.) For upgrade version only select choice firmware then flash it. 2.) For flash only language select choice language (must select same flash file for firmware) and press flash u will see its fast flash language.. That's ALL. P.S We now make pack description for language will upload support area Best Regards. |
:p Good work , tested and work fine..... BR FATIFLAWR |
great thanks for u work wwww.gsmegypt.com reseller egypt |
With new exe only select language then flash it. Coz Some time with firmware flash will be have problem on phone. For x400 select first FFS and flash after that select CUST and press flash. ALL That's |
hi friend, help me!! i need x400 firmware. my x400 is dead for panaufo. |
i think its not our software fault its your fault coz firmware make problem only FFS and Cust best for change language dont need firmware,we will try tonight add firmware for x400. |
sir today i receive the ufotools but try to unlock a100 always give the error please help what is wrong why it give the error thanks zafar janjua |
i told before that our dongle now sell with ****ing tele-way cable and have more problem with cable please download on support area cable schema and try with that if can not unlock read flash and send file our mail we check again |
where is X400 Bulgarian lang. pack? |
Let me pack number we will add on support area |
thanks. i wait. ( it is your software ) |
@Ufoteam: did you upload X400 firmware ? and when we open x400_flash_files_up_in_01_04_2005 PanaUFO_3.1 will close. |
UFO is verry hard to use, use original flasher is good for u To day try unlock X400 don't work, use FREE unlock is GOOD Don't lose your times with UFO maybe in next update ;) |
Which cable r use for X400 ? X66 or X300. I try both but not connected. Its show only "ready" on status,not "press power on" after press read button. Is it right ? |
must be press power on after press read |
