02-15-2005, 01:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | I still cant use pbb! 1.Formatted hdd and install xp and service pack I. ( no any other software installed) 2.Install latest fls4 driver and phoenix 75-76-77 version and latest flash pack. 3.Updated my pbb dongle to latest version using online force update 4.Made hardware modification on pbb,as Zulea wrote in topic. ( some resistor should be changed ) 5.Connected pbb directly to pc and use 9v 1A power ! 6. I got always error: Reading data from phone Reading phone information No phone detected! Reading flash settings from file(s) Detecting FLS4 FLS4 detected FLS Licenses remaining 1000 Starting flash... Detecting FLS4 FLS4 detected Initializing prommer Detecting flash device... Detecting FLS4 FLS4 detected FLS4 found Flashing image FLS-X Initialization done Licences remaining: 1000 Erasing Flash... Erasing: 5% Erasing: 10% Erasing: 15% Erasing: 20% Erasing: 25% Erasing: 30% Erasing: 35% Erasing: 40% Erasing: 45% Erasing: 50% Erasing: 55% Erasing: 60% Erasing: 65% Erasing: 70% Erasing: 75% Erasing: 80% Erasing: 85% Erasing: 90% Erasing: 95% Erasing: 100% Time Taken to Erase 72.485 Start programming flash memory... Programming: 5% Programming: 10% Programming: 15% Programming: 20% Programming: 25% Programming: 30% Programming: 35% Programming: 40% Programming: 45% Programming: 50% Programming: 55% Programming: 60% Programming: 65% Programming: 70% Programming: 75% Programming: 80% Programming: 85% Programming: 90% Programming: 95% Programming: 100% Programming done!!! Time Taken to Flash 40.547 Total Blocks ca.334 After MCU SW flashing delay2000ms Flashing PPM FLS-X Initialization done Licences remaining: 1000 Erasing Flash... Erasing: 5% Erasing: 10% Erasing: 15% Erasing: 20% Erasing: 25% Erasing: 30% Erasing: 35% Erasing: 40% Erasing: 45% Erasing: 50% Erasing: 55% Erasing: 60% Erasing: 65% Erasing: 70% Erasing: 75% Erasing: 80% Erasing: 85% Erasing: 90% Erasing: 95% Erasing: 100% Time Taken to Erase 14.563 Start programming flash memory... Error! MCU did not ACK Flashing failed. WHAT DO I DO WRONG???? |
02-15-2005, 04:53 | #3 (permalink) | |
No Life Poster Join Date: Jul 2003
Member: 33804 Status: Offline Thanks Meter: 22 | Quote:
For me flashing successfully with almost models but with N8910 and N6510 never done in PPM part! Always stop after erase PPM! WBR | |
02-15-2005, 10:40 | #6 (permalink) | |
For me problem in flashing N6510 as I said above! And I can't flashing PPM including choose PPM only! Almost other models work fine! Could you advise something? Thanks in advance! WBR | |
02-16-2005, 20:50 | #9 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Quote:
Best regards, Zulea | |
02-17-2005, 08:32 | #11 (permalink) |
Member: 33804 Status: Offline Thanks Meter: 22 | @Zulea Could you answer my above question? I don't think that my problem is wrong power supply!!! My PBB is working fine with almost Nokia models.Tested too many times with almost WD2 and DCT4 models and always success!!! Only had problem on N6510 and N8910 PPM part!!! Software always give me error after erasing PPM part of these models!!! Thanks in advance!!! WBR Last edited by hakima; 02-17-2005 at 17:56. |
02-17-2005, 10:36 | #13 (permalink) |
Member: 33804 Status: Offline Thanks Meter: 22 | @Lampin -My PCB is FLS4v6c!!! Here is all of my steps which just tried before post question here: -Already tried with all of these power supply: 6V-1000mA,7,5V-1000mA,9V-1000mA -Already tried with @X_Shadows's solution (HW and SW) -Uninstall all phoenixs and flash pakages in my PC including Clean HDD and Windows(Windows 2000;XP pack 1 and 2;Windows 98 second edittion) before install Phoenix and Flash package. -Already played with all mode of LPT which I can : ECP,EPP,ECP+EPP,Extended Mode,..etc,.. -Already tried with 3 PCs and all of them are Pentiumn not Celeron and all of them are Pentium 4 so higher speed than P3 700MHZ -Already read almost Service Buletins which I can download in PBB support site and too many other one which I can find on the net and from PWS -Already tried to modify service cables with almost pinouts which I can find on the net -Already tried with uninstall and reinstall newest Fia Package and FLS-4S driver 2.04. -At least : I haven't got any problem with almost other models but only had problem with N6510,N8310,N8910 PPM part!!! Now I'm trying to mesure and study why I can't get 3,9V-4,1V from main board as ******** said above about HW mod solution!!! And as I can see,almost member here had the same problem If you still need more details about all of my trying please let me know! Hope you can help me out! Thanks in advance! WBR Last edited by hakima; 02-17-2005 at 18:03. |
02-17-2005, 11:47 | #14 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | @ hakima Try remove ANY LPT cable extension that you use! If you have PCB v6c, not need anymore any modification to get right supply voltage for the phone!! If you not get 3.9-4.0 volts for the phone, there is 2 reasons: 1. your Power Adapter is the NOT right one (not stabilised well, and not give enough current when high consumption from phone). 2. yout PBB have some hardware problems, so try ask your reseller for exchange (but do thois only after try what I say here). The mostly probably problem is number 1. You use wrong or bad pwer supply adapter and/or use LPT cable extension. Here are some examples of power adapters who work well: http://www.minwa.com.hk/newDesign/pr...id=1215&code=2 http://www.minwa.com.hk/newDesign/pr...id=1216&code=2 http://www.minwa.com.hk/newDesign/pr...id=1269&code=2 I use MW 9110 GS to test all boxes, and this work well on 2 PC's and 4 laptops that i have here. Just set output to 7.5 volts, and PLUS in the middle of connector. Also there is right connector who fits well like Nokia charger connector. If you want a switching regulated one, can try this: http://www.minwa.com.hk/newDesign/pr...?id=832&code=1 Also desk stand power adapters from Teleway works well without any problems: http://www.one-stop-factory.com/prod...e=Power+supply Just set output to 7.5 volts, and PLUS in the middle of connector. The main problem when using this desk stand power supply is uotput voltage can be easy set to wrong higher value (from wrong mistake or from past operation with power supply on another device) and can damage your PBB easy if not carefull each time. best regards, Zulea |
02-17-2005, 12:59 | #15 (permalink) |
Member: 33804 Status: Offline Thanks Meter: 22 | Thanks for your help but as I can see maybe U did not read my above post carefully. I already flashing successfully with almost other models including WD2 which require more consumptive power current than DCT4 type! Am I right? Otherwise I will continue try to find out other Power supply! Thanks in advance!!! WBR Last edited by hakima; 02-17-2005 at 18:08. |
For those who flash phones using PBB... | shafnashaji | Phoenix Black Box | 0 | 03-28-2006 14:17 |
Sell used PBB and 100% working! | Gsm-W | Sell ur Old and Used Stuff | 0 | 10-17-2005 12:19 |
SIM CARD NOT VALID using PBB ON A N6600 | stevie | Phoenix Black Box | 8 | 07-25-2005 12:54 |
Repairing 6230i Bluetooth using PBB | UnlockBR | Phoenix Black Box | 0 | 05-30-2005 22:29 |
how to use pbb nec unlocker | ryumahon | Phoenix Black Box | 1 | 04-08-2005 14:50 |
