07-26-2006, 09:48 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 304803 Status: Offline Thanks Meter: 0 | Flashing Problem - Help! I have a PBB or PBB2 (don't know) Box. I have installed all drivers, and also Phoenix starts normal. When I want to flash a phone, I always get an Error. The following info is displayed: Detecting FLS-4 Device FLS-4 detected FLS device init status ok Flashing Image (danach beginnen die beiden Balken zu laufen) FLS-X ok Error Current mode of Programming Device Service Flashing Fail I also get a window with Hex codes displayed. I get this error, with every phone (1100, 3120, ...). I also tried an E61, and N80 (over USB) and get similar problems (stops flashing after phone reboot). Please help. SJ |
08-11-2006, 13:07 | #2 (permalink) |
Crazy Poster Join Date: Aug 2001 Location: United Kingdom
Member: 5661 Status: Offline Thanks Meter: 1 | I too am getting the same error whilst trying to flash a 6680...... Please reply on this thread Pbb Team...... Reading data from phone Reading phone information Reading product type Reading product code Reading PSN Get flash file names Reading IMEI Reading HW version Reading flash settings from file(s) Initializing Detecting FLS device. FLS-4 detected. FLS device init status OK FLS Licenses remaining 1000 Starting flash... Initializing Detecting FLS device. FLS-4 detected. FLS device init status OK Initializing prommer Initializing Detecting FLS device. FLS-4 detected. FLS device init status OK Flashing image FLS-X Ok... Error! Current mode of Programming Device: Service Flashing failed. HRESULT 0x840100cd (-2080309043) Br's Pmagroup |
08-11-2006, 16:02 | #3 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Greece, Veroia Age: 45
Member: 68628 Status: Offline Thanks Meter: 7 | Your problem can be solved probably here If you change your dongle from PKD or PKD-RD to FLS-4s the program will tell you which is the problem " bootstrap file not found" or "MCU did not ACK" etc.. |
08-16-2006, 17:55 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: not fixed yet
Member: 138305 Status: Offline Thanks Meter: 2 | Quote:
To work on phones, connect Box on LPTx port and start Phoenix If You done correct installation all job will go successfully. | |
3310 Flash problem. HELP! | maxmix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-02-2004 11:53 |
v70 flashing problem help! | ABCom | Motorola P2k | 0 | 11-21-2003 21:20 |
V200 Flashing problem HELP!!!!! | AlexG | Trident/AGERE Platform | 3 | 10-03-2003 09:15 |
S300 flashing problem help-help-help!!! | xacker | Trident/AGERE Platform | 7 | 07-21-2003 22:42 |
8250 flashing problem...help! | raingod | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2002 21:50 |
