Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 04-18-2006, 13:16   #1 (permalink)
Member: 134761
Thanks Meter: 40
how to find viola connection in pbb
pls any one can tell me how to find viola connection in pbb, cause I can not flash dead phone ( bb5 ) with usb
Old 04-18-2006, 13:28   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
PBB doesnt support it.
No such kind of viola you wanted is available via this box.
WBR,
Kolesom
Old 04-19-2006, 07:32   #3 (permalink)
Member: 134761
Thanks Meter: 40
so sir, how to used pbb with usb dead ? I have already to update to version 130 , and wanna flash dead phone ( bb5 ) with usb ,,, thanks for your reply
Old 04-20-2006, 18:03   #4 (permalink)
alif30's Avatar
Member: 57138
Thanks Meter: 4
Use Phoenix 1.30.. manage conection=> select no conetction.. flash dead phone with usb.
Old 04-21-2006, 06:50   #5 (permalink)
Member: 134761
Thanks Meter: 40
can you give step by step for activated usb dead for pbb thanks
Old 04-22-2006, 11:23   #6 (permalink)
alif30's Avatar
Member: 57138
Thanks Meter: 4
To flash a dead phone via the USB cable:
1.Install the data package for the product to be flashed.
2.Select the product from the File->Open product menu item.
3.Select NO CONNECTION in the Connections drop down list.
4.Connect the phone to the PC with a USB cable.
5.Select the variant in the Product Code drop down list.
6.Check the Dead phone USB flashing check box.
7.Press the Start button.
8.Follow the instructions during flashing.
NOTE: This flashing method requires user actions in order to be successful.
Solution : HOW TO FIND PIN OUT in SPD CPU bestncheap VE-KING 21 01-02-2009 20:27
How To Used Usb Dead In Pbb CONG YANG Phoenix Black Box 0 08-20-2006 09:26
how to find security code in nokia dct4 models using ufs grapher UFS2 + UFS3-Tornadoflasher 3 08-03-2005 12:05
How to find Phone id in MW 30xx Mehvishal Infineon C16X M51 & ARM7 M52 BASED 22 02-02-2002 16:19
Page generated in 0.15622 seconds with 10 queries
