Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 04-24-2005, 11:31   #1 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
i allways have this problem how to solve it
Reading data from phone
Reading phone information
Reading product type
Reading product code
Reading PSN
Get flash file names
Reading IMEI
Reading HW version
Reading flash settings from file(s)
Initializing
Detecting FLS4
FLS4 detected
FLS Licenses remaining 1000
Starting flash...
Detecting FPS-8
No response from prommer
Detecting FPS-10
Detecting FLS4
FLS4 detected
Initializing prommer
Detecting flash device...
Detecting FLS4
FLS4 detected
FLS4 found
Flashing image
FLS-X Initialization done
Licences remaining: 1000
Error! MCU did not boot
Flashing failed.
Flashing failed.
Error occured during the flashing procedure.
HRESULT 0x8004001a (-2147221478)
this come when i flash 7260 and 6600 7610 6670 fbus
but with 6630 its working fine
can any one tell why thats happn
thanks alot
Old 04-24-2005, 12:01   #2 (permalink)
4R
4R's Avatar
Member: 15800
Thanks Meter: 66
freind kindly check kble first then the setting in pheonix software you must select ryt kind of fone....
Old 04-24-2005, 12:13   #3 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
what u mean about checking the setting in pheonix
i'am new in pbb
Old 04-24-2005, 13:53   #4 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
still the same with 7610
Old 04-24-2005, 15:11   #5 (permalink)
lampin's Avatar
Member: 637
Thanks Meter: 152
is you PBB conected using parallel extension cable? if so connect it directly to your parallel port ang make sure use 7.5v of power supply..
Lampin
Old 04-24-2005, 17:34   #6 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
Lampin
i'am using nokia orginal charger
Old 04-24-2005, 17:49   #7 (permalink)
Cheater -Don't Deal with him-
parot's Avatar
Member: 13583
Sonork: 100.1613271
Thanks Meter: 139
if you are using the charger,, then it should work well......,,,,,,
fbus connection selected.???.........scan product ok??
lpt set to bi-directional? do you hav good cables.......??
consider this things mate......
try and try.......
br,
parot
Old 04-24-2005, 20:07   #8 (permalink)
mr_x4you's Avatar
Member: 4989
Thanks Meter: 11
make sure power supply is ok, if still not work, remove bsi resistor from cable
Old 04-24-2005, 21:50   #9 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,449
Nokia original charger NOT working good because give only 5.7v !!!
PLEASE use an power adapter who give 7.5v and 1A !!!
This subject was discussed MANY times here.
Best regards,
Zulea
Old 04-25-2005, 08:50   #10 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
Best regards,
Zulea
sorry man but i'm new with pbb
Old 04-26-2005, 08:39   #11 (permalink)
momayaz's Avatar
Member: 135532
Thanks Meter: 17
ok isolve this problem with remove the ic and make dirct connction to use usb and orginal nokia charger and its fine now thank you all for help
Old 05-10-2005, 18:16   #12 (permalink)
Member: 62016
Thanks Meter: 48
7.5v and 1A it well work on pbb [email protected] .co.in
this is how to solve problem N70 no network fone Nokia Hardware & Hardware Repair 8 02-10-2007 03:46
GD55 imei repair problem,how to solve this error? maxijazz Infinity-Box 8 08-14-2006 10:17
C616 Please Wait Prob !!!! How to Solve it ? Aamir_Zia NEC 7 01-03-2005 19:59
Page generated in 0.36048 seconds with 8 queries
