Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 05-29-2005, 15:14   #1 (permalink)
Member: 7586
Thanks Meter: 11
NEC e313 dead after flashing
Hello
who can help me with reviving NEC e313.
I flashed it with flash file from PBB support.
all was ok . Aflash write ok and also Cflash write ok .. all ok .
i removed batery and tried to power on the phone and its dead !!
Please help ..
Zulea , your flash files are not tested????! or where is the problem .
Can u help me please ?
pali
Old 06-05-2005, 22:35   #2 (permalink)
Member: 7586
Thanks Meter: 11
ZULEA !! whats up ??
why no answer from u man ?
i killed my e313 with flash from SUPPORT and my customer is VERY ANGRY , how to fix it ??
PALI
Old 06-06-2005, 08:40   #3 (permalink)
Member: 30940
Thanks Meter: 13
same hapen to me ... E313(Italy) dead after flash - i try with other flashes and flashers and nothing - ONLY WAY to make it alive is to flash with E228 flash & flasher, but camera have problem - upsidedown an when you switch to internal camera wich E313 havent you need to remove batery
Old 06-06-2005, 10:33   #4 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Contact me then I will help you out.
Best regards
Old 06-06-2005, 13:08   #5 (permalink)
Member: 7586
Thanks Meter: 11
@hakima
how to contact u ? your msg inbox is full .. cant send u private msg..
Pali
Old 06-06-2005, 15:59   #6 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Originally Posted by pali
@hakima
Pali
Just read my PM friend
Already gave you a link to download.
Best regards
Old 06-06-2005, 18:01   #7 (permalink)
Member: 7586
Thanks Meter: 11
@hakima
nothing received yet
pali
Old 06-06-2005, 20:42   #8 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
@hakima
pali
Sorry for my mistake.Message has been sent again.
Best regards
Old 06-08-2005, 10:54   #9 (permalink)
Member: 30940
Thanks Meter: 13
solution for dead NEC E313 who power only with E228 (uran) flashes :
find SW11part1 and SW11part2 arhive with flashes for NEC
install software and in directory you will find 4 flashfiles in *.ifs format
you need only IPLSD2_313_J2_IT_099_05fa12.ifs
find on this forum IFSDecoder by KWULL - thank you man for this
decode this ifs file with decoder and put output files in directory with IPLT for USB 1.0.5 (atom flasher)
correct paths and checksums in manifacture.txt to use decoded files
flash it and 100% your nec will be allive and will be E313
if needed - reset it with NEXUS
Old 06-08-2005, 19:43   #10 (permalink)
Member: 7586
Thanks Meter: 11
@symbiah
where to get those files?
do u have them ?
Pali
Old 06-08-2005, 21:07   #11 (permalink)
hakima's Avatar
Member: 33804
Thanks Meter: 22
Why do you need to decode *.ifs files when IPLS202i flasher has been released to public long time ago?
Best regards
NEC E313 dead after downgrade... HELP!!! MaDMaN666 NEC 25 04-01-2006 15:55
NEC e313 dead after flash vishalmadhvani NEC 16 11-04-2005 06:19
nec e313 dead after flashing gsmservices NEC 2 10-24-2005 17:02
NEC E313 dead after using ATOM FIRMWARE help is at hand! paulisthebest NEC 1 08-01-2005 18:06
Nec E228 dead after flashing with e313 firmware! baushino NEC 5 03-06-2005 01:06
Page generated in 0.37145 seconds with 8 queries
