Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 05-22-2006, 14:49   #1 (permalink)
Member: 18832
PBB2 Drives me mad.
Hi there!
I got my pbb2 recently. First of all, LPT connection never worked. I got the box to work with USB connection. since then I was able to flash 2 phones with it, and after that nothing. The device is recognized in the device manager, as nmp fls-4, and virtual port on fls-4, but when I try to search in Phoenix, no connection is found at that certain port number. It really drives me mad, please help solving this problem. I use latest driver and a quite fresh Phoenix release, but not the last.
WBR
e-studio.hu
Old 05-22-2006, 18:47   #2 (permalink)
Member: 18832
I'm totally stuck with this box. I almost smashed it against the wall after installing-uninstalling phoenix/driver everything for xxxx times, and since then I cannot connect to fls-4 device through com ports, altough it is recognized in device manager. Plz help me to resolve this problem.
WBR
e-studio.hu
Old 05-22-2006, 22:27   #3 (permalink)
Member: 137474
Sonork: 100.109924
I will have tommorow my PBB2 pleasse don't do nothing tommorow I will exacly tell you how to use this hardware. bye
Old 05-22-2006, 22:48   #4 (permalink)
Member: 138819
pbb2 no ok
WBR
e-studio.hu
hi
PBB 1 OK and GTI OK
PBB2 NO RECONGNIZED WITH PBBTOOLS 6.0 OR 7.0 ( lpt or usb ) drivers ok
PLZ help me for this pb
thanks
bs
Old 05-23-2006, 04:32   #5 (permalink)
lampin's Avatar
Member: 637
check your Lpt port settings......should be at ECP
Lampin
Old 05-23-2006, 06:44   #6 (permalink)
Member: 138819
Lampin
hi
Ltp port is ECP
pbb2 no recongniezd
pbb1 yes
thanks
Old 05-23-2006, 07:06   #7 (permalink)
Member: 18832
Please assume that we tried all basic variations, that has been mentioned so far. Ofcourse I tried all LPT port settings, all usb setting for usb connection, all virtual com ports and stuff.
Still my PBB2 is recognized, but only via USB, but phoenix cannot connecto to the fls-4 virtual com port.
Would be nice if Zula said some words on the issue.
WBR
e-studio.hu
Old 05-23-2006, 07:51   #8 (permalink)
Member: 76522
wait 4 pbb3 it will be more stable and cost 40 euro
Old 05-23-2006, 11:37   #9 (permalink)
Member: 18832
After playing with this fukking box for another 3 hours, I gave up. unless anyone comes up with some usable idea, it goes to trash. Impossible to use it. And i won't take "re-install windows and drivers" theories. That's not a solution.
WBR
e-studio.hu
Old 05-23-2006, 19:19   #10 (permalink)
Member: 137474
Sonork: 100.109924
Evryone who have problems with PBB2 pleasse give me log form blackbox7.0 and I give you answer what is problems. bye
COnnect PBB2 to usb and power supply 9V and unless 500mA
Old 05-23-2006, 21:18   #11 (permalink)
Member: 18832
Log from pbbmaintenance 7.0 "PBB2 Not Found". Is that enough? box is recognized in the device manager...
WBR
e-studio.hu
Old 05-23-2006, 21:40   #12 (permalink)
Member: 137474
Sonork: 100.109924
Then I tell you that connect PBB2 with LPT cable and power supply and run blackbox 6.0 and check this I thing you have low firmware from PBB1 I have in 1 for 3 this and this Pbb2 don't work me next 2pcs I have OK and working like a ham with lpt and usb without problems send PBB2 to resseler becouse he don't change firmware to higer or wait few day to zulea to update blackbox to 7.5 that will can update this pbb to pbb2 whitout problems i think. bye
Old 05-23-2006, 21:44   #13 (permalink)
Member: 18832
Thank you for advice.
On my laptop the pbbmaintenance 7.0 runs OK, I can change counters, box type without problems. But still, phoenix doesn't see the fls4 on the virtual com ports. So I assume the firmware version is OK. Nevertheless, i cannot connect pbb2 via LPT port neither on my desktop PC, nor on my laptop.
Cheers
e-studio.hu
Old 05-23-2006, 21:54   #14 (permalink)
Member: 137474
Sonork: 100.109924
post screenshoot from view blackbox 7.0
and I tell you why don't work. bye
Old 05-23-2006, 22:27   #15 (permalink)
gbluez's Avatar
Member: 73565
more than enough
See on what port is your FLS Virtual com port number. (control panel or device manager)
Then, try to manage conection on same port as FLS virtual is used. Manualy.
Forced it, if possible.
Still no help?
Unins. - reinstall phoenix (with 136). Then try to manage connection automatically. Still no connection detected?? I have no idea then......
GTi with FLSvCOM is often face this problem too, but not with LPT.
And, uh,, yes Mr. Zulea, why is GTi doesn't need any special way in order to handle new phoenix release??
WBR
motorola l6 drive me mad david laborator P2k Series 0 12-03-2007 15:55
The sound of rubber on asphalt is driving me mad!! Eden's Son CAR Electronics 2 03-14-2007 13:02
Help Flashing Driving Me Mad D600e sdduk Samsung Flashers, Software, Firmware. 1 02-09-2006 07:14
7110 drives me mad!:(plzzzz help! hulala.[uk] Nokia Hardware & Hardware-Repair Area 3 03-31-2003 17:28
Page generated in 0.35980 seconds with 11 queries
