Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 05-31-2006, 18:01   #1 (permalink)
garch's Avatar
Member: 138305
Thanks Meter: 2
PBB2 Installation Notes
What I need :
Drivers
FLS-4 Drivers HERE
Software
PhoenixBlackBox_v7.0 HERE
Phenix ( From Support Area )
Wintesla ( From Support Area )
Installation Steps :
Drivers
Run FLS4207.Drivers with PBB2 not connected.
PowerOn Your PBB2 ( I used 7.5v and -(°+ Polarity. )
Insert USBCable ( male-male ) on PC and then in PBB2
System will start searching drivers for installation... let system do that for You
wait ... there are some drivers to install, so be patient.
when complete system will tell You new hardware is ready.
Now You can start BlackBoxTool_v70.exe and see how Your PPB2 is configured.
Now You can "GO Support" and download what You need.
Software
Wintesla
Install Wintesla.exe and Restart PC
Start Wintesla Service Software
First time Wintesla will ask for a Login name, put "NN1" or "NN2"
Connect and Start to work
Phoenix
Take Your PBB2 and PowerOn ( I used 7.5v and -(°+ Polarity. )
Start Phoenix Installation
Installation procedure will tell Dongle not Found ( Retry or Abort ?) , don't worry just wait ...
a window will open for FLS drivers installation, let do the system yhe job for You.
when dtrivers installation will complete just press "retry" on Phoenix Installation Error window just leave
installation will continue ... and will ask for FLS driver one time again.
as before wait window system installation drivers comes up and, as before, let the system do the job for You
when complete, press "Retry" on on Phoenix Installation Error window just leave
Now take a coffe and wait
At the end You will need to restart PC and wait all *.dll files be registered on system
Finally start Your Phoenix Software .
System : XP-SP2 - USB-HUB v2.0
Old 06-01-2006, 08:39   #2 (permalink)
Member: 157834
good work but
Originally Posted by garch
What I need :
Drivers
FLS-4 Drivers HERE
Software
Drivers
Software
Wintesla
Phoenix
Good info Mr.grach, iam just use USB cable without Adapter thnx man nice Job
Old 06-03-2006, 11:43   #3 (permalink)
Member: 87188
Thanks Meter: 227
7.5V???
Then what this? :
Old 06-03-2006, 18:12   #4 (permalink)
Member: 157834
Originally Posted by Pufi164
7.5V???
Then what this? :
The PBB2 needs Adapter(7.5V) and USB A=A cable..
Old 06-04-2006, 01:36   #5 (permalink)
Member: 45351
Thanks Meter: 2
7.5V???
Then what this? :
I doubt this is PBB2???? MT Box maybe.
Old 06-04-2006, 08:22   #6 (permalink)
eeusebiu's Avatar
Member: 15078
Thanks Meter: 31
@josetolo_jr
yes this is Pbb2 box , can be powered with 7,5v ~ 9v.
B.R ,
Old 06-04-2006, 20:29   #7 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
And what about Diego software? Any advice?
BR,
Old 06-04-2006, 21:16   #8 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
Did you ever see PBB2, or you're just talking ???
Old 06-05-2006, 06:25   #9 (permalink)
Member: 45351
Thanks Meter: 2
Sorry my mistake. It's PBB2. Am just sad of my old PBB, got my point?
Old 06-11-2006, 16:41   #10 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
hoping next post will be how to flash or unlock phones using PBB2
Old 06-27-2006, 15:36   #11 (permalink)
Crazy Poster
Member: 271171
hello frieds
i have phoenix black box PBB firmwere version.0B
now i saw new apdation but i try it, i can't apdate now, how can i update, please give me some solution please, i appriciate your favour.
i hawe ppb maintenance v_5.0 tool, i am waiting for your sms.
Thanks
Old 08-12-2006, 16:22   #12 (permalink)
Member: 188726
Thanks Meter: 5
greeting has all
As the technical support does not re-lay in our message, they refere to the internaut of the forum
there is you somebody who can us point out or ' they can telecharger the setup, of PBB2?????
thanks for a reponce
salut a tous
Comme le support technique ne reponde pas à nos message , on se refere au internaute du forum
y a t'il quelqu'un qui nous peut indiquer ou' on peut telecharger le setup, du PBB2?????
merci d'une reponce
ciao a tutti
il supporto technico no ci respondi ai nostri messaggi e-mail, percio mi riferisco ai navigatore dei forum
dove possimo scaricare l'istallazione ((setup.exe)) du phoenix black box2???
grazie per una resposta
distinti saluti a tutti
abdo
Old 08-13-2006, 07:20   #13 (permalink)
garch's Avatar
Member: 138305
Thanks Meter: 2
with BlackBoxTool.exe You can set Your PBB2 to works in three ways
- FLS
- PK1
- PK1-RD ( research & developement the most reach of phoenix options )
When in Phoenix menu select "Manage Connections" to set how You wish to work ( FBUS or USB ) and let Phoenix try fo find out which connections are ready in Your system.( You can setup that manually )
For FBus Mode , Connection-Port, must be the same as in Your FLS Driver setup ( Look at Windows Control Panel : FLS icon )
For USB Mode same as Your DKU-2 Cable Driver
If all is ok, attach phone and press "Scan For Products"
From this point on You can make everything You want on phone
To flash phone just press "Software Update" option check Your Firmware before and if You need download from Support Area
Regards
Old 08-14-2006, 14:03   #14 (permalink)
Member: 63961
Thanks Meter: 11
Do I have to click Write SN
on Blackbox V7, Do I check FLS and do what? Sorry first time to use PBB2
Old 08-14-2006, 14:12   #15 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
Thumbs up bro
u dont need to write ne thing in this or edit
jaff new setup 1.1.1 how,s install friend0007 JAFWM 4 05-29-2010 06:48
How to Fix: Notes App Does Not Save My Note After iPhone Jailbreak d'odders iPhone 2 / iPhone 3G / iPhone 3GS 0 12-06-2009 02:55
Special Nissan Note Navigation DVD System With HD Monitor - For Nissan Note 2006-200 IPMART ipmart WebShop 0 09-25-2009 01:50
***note***why vodastar clip getting dead***note*** chiragp Vodafone Star 6 04-14-2009 19:14
Vito Audio Notes Installation Problem On Wm5 My_Immortal HTC & PDA WM( With Touchscreen) 0 11-23-2006 02:12
Page generated in 0.25601 seconds with 10 queries
