Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 06-21-2006, 16:28   #1 (permalink)
Member: 125718
Pbb2 No Flash
NOKIA 2300 6020 The cellular phone is all right
Old 06-21-2006, 16:30   #2 (permalink)
Member: 125718
Can connect to come to hand the machine, but can't write
Old 06-21-2006, 17:27   #3 (permalink)
Member: 22991
The same problem.................
Old 06-21-2006, 17:54   #4 (permalink)
Member: 14515
Sonork: 100.77248
Switch the box to FLS-4S mode and let's see what the problem is.
BR Roy
Old 06-22-2006, 05:06   #5 (permalink)
Member: 261622
try to change adapter power 9volt unless 700ma
Old 06-22-2006, 05:18   #6 (permalink)
alex12345's Avatar
Member: 152573
same problem here
Old 06-22-2006, 06:54   #7 (permalink)
Member: 88996
for me too but can flash bb5 with usb..........
Old 06-22-2006, 10:40   #8 (permalink)
Member: 125718
Fls-4s .................
Old 06-22-2006, 11:02   #9 (permalink)
Member: 14515
Sonork: 100.77248
Yes, thx I've thought bootstrap problem....You need to reinstall Phoenix but...After uninstall Phoenix reboot your computer and you must delete directories manually. Delete C:\Program Files\Common Files\Nokia ,C:\Program Files\Nokia\Phoenix\Framework, C:\Program Files\Nokia\Phoenix\tp , C:\Program Files\Nokia\CDMA, C:\Program Files\Nokia\TSS Instrument API, C:\Program Files\Nokia\TssProductApiA and all dll files in C:\Program Files\Nokia\Phoenix\ directory. After it install Phoenix 136. After reboot and registering dll's run 138 update. After them you can flash without any problem.
BR Roy
Old 06-22-2006, 18:55   #10 (permalink)
Chevka's Avatar
Member: 82106
@ Royslade
Yes it's true sir but it only work with PBB 2 and when I try to do BB5 Flashing with PBB 1, it always say an Error about ADL Loader.
how can I fix that?!??
Thanx in advance....
Old 06-23-2006, 06:30   #11 (permalink)
Member: 14515
Sonork: 100.77248
Which phoneix u use ? Which DKU-2 driver u use?
Use the latest Phoenix. This will install the latest DKU-2 cable too.
BR Roy
Old 06-24-2006, 20:32   #12 (permalink)
Chevka's Avatar
Member: 82106
I use Phoenix 136 sir...
btw, can you make Request File (ASK) and write RPL file with PBB 1 or PBB 2?!??
Old 06-25-2006, 07:13   #13 (permalink)
Member: 14515
Sonork: 100.77248
No, I can't.
BR Roy
lg kg110 no flash no unlock:::ANSWERED::: kosharaa PolarBox 2 3 01-31-2009 10:31
lg kg110 no flash no unlock:::ANSWERED::: kosharaa PolarBox 2 3 01-19-2009 18:20
b300 unlock done no flash no imei change! scutarus UST Pro II 4 01-12-2009 01:29
A689 no flash - no cable hranasingha Chinese Models & Cloned Phones 1 12-08-2008 01:18
Page generated in 0.37998 seconds with 12 queries
