Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 01-28-2005, 18:33   #1 (permalink)
Member: 105916
Recommended operation system and some useful info!
If you have chance, make one clean partition, or use another hard drive, and
- install win2000
- install win2000 service pack4 (you can download it from internet for free)
- install DRV_FLS4_204.exe ( DOWNLOAD LINK )
- install phoenix_service_sw_2004_39_7_70.exe (you can find it in PBB support area)
- install phoenix_service_sw_2004_46_4_75.exe (you can find it in PBB support area)
- install phoenix_service_sw_2004_46_5_76_upd.exe (you can find it in PBB support area)
- install DKU-2 drivers ( you can download it from nokia site CLICK HERE )
If you havent USB2 port on your PC, we recommend to buy PCI USB 2 card, it will be more stable for APE flashing! ( only 8-10 euro in PC shop)
Always connect PBB direct to LPT port!
Old 01-28-2005, 18:39   #2 (permalink)
dani146's Avatar
Member: 3812
BIG THANKS for all this help
Old 01-29-2005, 15:04   #3 (permalink)
Member: 40984
I tried all but still got problems flashing failed at 14%.I tested 6100,3650 and 6270 no one can success flashing with PBB,but I doing scan product all run well,what's problems???I using v7.5 with 1 Amp power supply and original adaptor also same result,I need your help!!!
Old 01-29-2005, 15:11   #4 (permalink)
mr_x4you's Avatar
Member: 4989
try to upgrade FW with force update selected
Old 01-29-2005, 15:34   #5 (permalink)
Member: 40984
update 3 times already,now my firmware 05.
Old 01-29-2005, 16:15   #6 (permalink)
Member: 61077
Try with another possible cable u can find.
Old 01-30-2005, 04:40   #7 (permalink)
kumkon's Avatar
Member: 5509
contact your reseller for exchange the new box.
Old 02-24-2005, 00:26   #8 (permalink)
Member: 119338
The problem "mcu error" and some other strange errors occurs with different phones on original nokia fls-4 too
as former nokia FLS-4 user i can tell you, Phoenix isnīt that stable nokia tells....
DONīT: install data packages or phoenix without deinstalling old one before
DONīT: install more than one phone type without restarting your pc.
DONīT: downgrade FLS-4 drivers if asked during installation of data packages
DONīT: use WIN XP Home Edition (works, but more troubles than XP PRO or WIN 2K)
DONīT: use usb hubs for data cables (dku-2...)
DONīT: use notebooks with port *******tors for parallel port
DONīT: use nokia pc suites parallel to phoenix, may cause driver violation
DONīT: use pc for other purpose during flash process
DONīT: downgrade any type of phone, itīs a good chance to kill phone
DONīT: start flash process on 7650 before boot process has finished, may kill phone
DONīT: deplug phone during flash process, may kill phone
DO: if you can, use pc for phoenix/tesla flash solution only
DO: make a new clean windows installation before installing flash solution
DO: use pc with 4 or more REAL usb ports (no hubs)
DO: if you use notebook, plug power cable, accu may be an instable power source
DO: make second partition for cloning flash solution
DO: use norton/symantec ghost for backup flash solution on second partition
DO: plug all needed cables BEFORE installing phoenix
DO: if you have a perfect working flash solution, make clone/backup
DO: if you reinstall or update phoenix, make backup before
DO: plug n-gage data cable for n-gage flashing; itīs needed during flash process
DO: if you use other software than phoenix too, restart pc before flashing
WARNING: sometimes phoenix KILLS whole pc system after installing without deinstall and restart before
SOME LITTLE INFO:
errors may occur too if you try to install minor data packages with one minor package missing in between.
install major DP, then minor 1.1, 1.2. 1.3 ...
after installing one phone type, restart pc, then install then next phone type...
after deinstalling one DP, restart too before installing the new one
if you still have troubles, deinstall phoenix, restart, make backup, install phoenix again
that should solve it
HAVE FUN!!!
Old 04-11-2005, 19:04   #9 (permalink)
Member: 133218
did you try to read this maybe it will help??
if you tried pls inform me
Old 04-23-2005, 05:17   #10 (permalink)
Member: 44664
pbb is ask for deskkey for start the software
Old 04-23-2005, 05:17   #11 (permalink)
Member: 44664
can any one tell me how to should this problem
Old 05-02-2005, 02:50   #12 (permalink)
Member: 65186
This PBB after almost 1 mth of usage its still very buggy even though it have several updates. It alway detect PBB in presence but after awhile it will prompt u no deskey found and you cant even cancel it as it keep on popping out after u have close the pop up..
Old 05-21-2005, 11:34   #13 (permalink)
andrew14's Avatar
Member: 78367
deskey is always popping up......
whats the problem with that?
Old 05-21-2005, 12:14   #14 (permalink)
Member: 14515
Sonork: 100.77248
Check your power supply.
It has at least 7,5V 1A stabilized for correct work.
BR Roy
Old 05-22-2005, 02:18   #15 (permalink)
andrew14's Avatar
Member: 78367
its hard for me to use this soft it isnt like griffin and ufs very diff.....
can pbb run in xp pack 2?
what is the maximum volt for pbb to run i hav 1.2 A adaptor with voltage selector cn i use that???????????
Can i use ns pro under linux operative system ? mcecaro NSPRO 2 08-04-2009 03:10
Doubts about how to flash and some other info... luskao JAFWM 12 10-14-2006 13:23
Where can I get some operating system sample codes for smartcard? Maj Sim Cloning and Scaning 1 05-25-2005 09:44
Hey guys.. just trying to get some useful info from the experts! Interlude Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-23-2003 00:03
get some useful info masterross Sim Cloning and Scaning 0 03-31-2002 02:55
Page generated in 1.56657 seconds with 12 queries
