Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 12-21-2004, 21:18   #1 (permalink)
zulea's Avatar
Member: 5325
Small hardware modifications required for some models
Hi,
For better work and to avoid problems when flashing 6230 and 9500 Nokia phones, small hardware modifications on PBB is required. In fact 3 resistors should be replaced with another values.
Please check attached pictures for more details.
If anybody is not skilled enough in soldering and replacement of SMD components, please don't do this alone and try ask a friend who have enough skills to make this modifications
Best regards,
Zulea
Old 12-22-2004, 14:40   #2 (permalink)
Member: 19294
toooo late zulea
Old 12-22-2004, 17:46   #3 (permalink)
Member: 7650
I have changed he three resistors. Have problem with 1 ohm. Cant find smd for this one , replaced with 1/8 watt ordinary resistor.
My voltage reading after modification is 3.8 V. Is this close enough.
Old 12-22-2004, 20:40   #4 (permalink)
dani146's Avatar
Member: 3812
Originally Posted by PROFESOR
toooo late zulea
Better late than never
Old 12-22-2004, 22:14   #5 (permalink)
mr_x4you's Avatar
Member: 4989
Looooool, I have 3,99V !!!!!
Old 12-23-2004, 12:38   #6 (permalink)
Member: 5992
It's working like a charm.
thank you Zulea.
Old 12-28-2004, 08:29   #7 (permalink)
maxijazz's Avatar
Member: 93787
Originally Posted by zulea
Hi,
Best regards,
Zulea
hi.i opened the case of my box.it looks like the second picture(i mean the green one).but not the same.how can i know should i do that changes?can you help me please?
Old 12-28-2004, 08:42   #8 (permalink)
mr_x4you's Avatar
Member: 4989
Look on the board and see what PCB version you have.
It's FLS4V2 or FLS4V5 ?
Old 12-28-2004, 08:48   #9 (permalink)
maxijazz's Avatar
Member: 93787
its fls4v2. but not the same as in the picture.for example 47ohm is not at that place shown in the picture.is it important?im asking cause im afraid of making wrong replacements.
Old 12-28-2004, 08:51   #10 (permalink)
maxijazz's Avatar
Member: 93787
sorry man i found the problem.it was my fault.thank you for your help.
Old 12-31-2004, 15:09   #11 (permalink)
fgl30's Avatar
Member: 27881
My reading (tension) give me 4,35 V, I´m using 7,5 V stabillized 500mA power supply............. and sometimes not enough to keep phones powered on...... specialy TDMA ones........
Old 01-01-2005, 10:28   #12 (permalink)
Member: 3015
Hi plz i need some information about 9500 flashing , must do this modification to do it? because when i put fbus cable phone can t power on in normal mode only white in internal screen
some help plz
Old 01-01-2005, 11:41   #13 (permalink)
Member: 22222
no body answer in this forum i have proplems t flash 9500 &6630
and no helpe in that now i have problem withe custumer the set all did
and i use the *** we to flash
6630 need fbs-8 ......so what is it this fbs-8
9500 i flash it it is go to 90% and after that MCU FAIL
I BY THIS PBB FOR 9500& 6630 ONLY I DONT WANTE TO USE WHITH ATHERE
SO PLS HELP
Old 01-01-2005, 13:44   #14 (permalink)
Member: 3015
no answear always
Old 01-06-2005, 00:40   #15 (permalink)
zulea's Avatar
Member: 5325
some help plz
Hi,
Try to make changes on your cable like is shown in attached picture.
Best regards,
Zulea
Is using power through box dangerous for some models pearsonjohnboy BB5BOX 6 11-08-2007 18:34
New Update Required for Alcatel Models... G*Mughal*G Infinity-Box 1 09-30-2007 01:47
why ub doesnt add addons service for some model speedstarrr Universalbox 0 08-03-2007 12:41
Page generated in 0.37174 seconds with 12 queries
