Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 07-28-2006, 07:38   #1 (permalink)
andr3as's Avatar
Member: 68628
Some research about "PBB not found" problem
@Zulea if this helps you and gives you some clues about the solution of this problem...
I installed the BB5 Reaper - Phoenix cracked so that doesn't need a dongle to start - and tryed to communicate with PBB2.
*Just to remind you i have the same problem as many people that did the mistake to use the LPT connection and after that connect the box to USB, with the result phoenix cannot open because it doesn't see the FLS (see attached photo).
Retuning to my subject, i installed it and runned phoenix WITH my PBB2 attached... For my big suprise Phoenix saw FLS device and scanned the phone but i couldn't use it for flashing cause it said i had no licenses (the counter said it was zero) but as you see in the photo maintenance tool says a big number....
******I experiened a similar problem twice with the original fls
1st time phoenix & tesla couldn't see the fls (does it remind you of something) and NOKIA send me a new one...
2nd time i couldn't update the counter with the same result as the first time****** The funny is that with yours box i am experiencing both problem at once
I wish that you are working on it to fix the problem (as it seems to be a firmware problem) and hope that we have a solution soon....
Best Regards
AnDr3aS
"W200i memory stick not found" --- Problem J@zz Sony Ericsson Hardware Repair Area 9 05-06-2010 06:31
Freind's how you are solved problem "Key Not Found" haveri SwS_SaG_BoX 28 10-10-2006 14:11
one more comment about "dongle not found" problem gyuszko Dongle Problems (USB-Smart) 3 03-20-2006 21:46
"Phoenix Application not found" !! 3510i problem ! crown Trisha & Matrix Flasher 5 12-13-2004 09:10
For "DEVICE NOT FOUND" problem, try this !!!! GSMassistance ARM9 BASED M62 / M62+ 0 02-23-2004 12:04
Page generated in 0.21703 seconds with 12 queries
