Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Phoenix Black Box
Old 02-12-2005, 14:23   #1 (permalink)
kone's Avatar
Member: 17753
Exclamation WARNING PBB NEC code reader is Phone Killer !!!
I have bougt a PBB box and everything is ok !
I have started to make money until Zulea gives us a gift named NEC 3G unlocker which starts killing phones.
Now Im buying a new phone to every customer that give me NEC phone for unlocking.
Old 02-12-2005, 14:30   #2 (permalink)
Member: 33915
i have the Pbb and i have used Nec unlocker .... untill now everything is oki ...please explain what is wrong whith the prones that are brocken ... ? what was the fw version ... and what moddel !
Old 02-12-2005, 14:53   #3 (permalink)
hakima's Avatar
Member: 33804
Yes,just tested by me too many times also
That GIFT works fine and the only mistake after unlocking is IMEI part has been changed
So could you please let me know what happen with you???
WBR
Old 02-12-2005, 14:55   #4 (permalink)
Alkapone's Avatar
Member: 19265
Not only for kone, a lot of people has this problem: Please wait, init..., IMEI 000000000000000 and else.
For me 2 pieces dead.
B.R.
Alkapone
Old 02-12-2005, 15:03   #5 (permalink)
dani146's Avatar
Member: 3812
First thing is that PBB is for Nok. phones not for NEC !!!
Please note, when it was posted, the solution for nec was free of charge
and with the "use it on your own risk" mark. I have made enough NEC phones
to realise that the only ones with problems are v22 and up...
For that you can use remote uni-server.ro or solution from Spear or many more...
No need to blame no one.
Old 02-12-2005, 16:17   #6 (permalink)
Alkapone's Avatar
Member: 19265
Maybe Zulea will make update for these problems ... I hope, because it will be nice to repair these already buyed phones. I have made few experiments, and understood, that if you try to unlock only one time for a phone, you wount have any problems (v18, v22, no difference), but if try to unlock 3-4 times (sometimes people trys, because phone relocks to first sim card that putted into it, and dont understand, that only sim lock code need'ed), nec will tampered.
I think, that damaged phones, only our problems, but update would be nice.
B.R.
Alkapone
Old 02-12-2005, 18:44   #7 (permalink)
dani146's Avatar
Member: 3812
yes - the solution is in work and will be posted free if succesfull...
Old 02-12-2005, 20:21   #8 (permalink)
kone's Avatar
Member: 17753
Angry
Yes PBB nec unlocker is phone killer !!!
Because 1 of the phones that PBB kills was prahistoric version which is possible to unlock with the first solution via keypad !
The phone was brand new and never touched !!!
After successfuly reading codes with NEC PBB reader, now im unable to enter codes because phone freezes with NEC logo on display,
After that i get 2 identic E616v phones with same version and only few diferent numbers in IMEI.
The first I have killed with PBB and the second I have succesfully unlocked with free cracked NEC code reader.
THANKS TO *** IF THERE WILL BE AN UPDATE TO REPAIR ALL KILLED PHONES !!!
Old 02-13-2005, 05:26   #9 (permalink)
zulea's Avatar
Member: 5325
Hi,
The NEC 3G software is made to be used MAINLY and (better) ONLY to phones with BLOCKED COUNTER! For NEC 3G phones without blocked counter there is free available code reader (and downgrader) via USB cable. Just use this, and use NEC PBB ONLY if you have phones with BLOCKED COUNTER.
Best regards,
Zulea
Old 02-13-2005, 10:50   #10 (permalink)
MaFiaaa's Avatar
Member: 57930
PBB is savelly way to unlock NEC 3G i unlock more of it
and unlock 2 E616 V22 after downgrad all is done 100%
Old 02-13-2005, 11:00   #11 (permalink)
garutech's Avatar
Member: 65222
Sonork: 100.65030
man try and downgrade then unlock with the box.
good luck
garutech
Old 02-13-2005, 20:21   #12 (permalink)
distefano's Avatar
Member: 29669
Arrow maestro
.... halo,
..... but for sure it will be teally GREAT DAY WHEN YOU WILL FINISH REPAIRER FOR PBB TOO
wbr
Old 02-14-2005, 07:41   #13 (permalink)
kone's Avatar
Member: 17753
good luck
garutech
I have allready done that !!!
Phone is completely f u c k e d
Old 02-14-2005, 07:44   #14 (permalink)
kone's Avatar
Member: 17753
Originally Posted by zulea
Hi,
Best regards,
Zulea
Come on !!!
Why dont you advertise that magic function ???
Old 02-15-2005, 19:25   #15 (permalink)
Member: 25392
i also killed nec with pbb
the problem aper if you read codes with pbb after donwgrade....
nenmobil
waiting for a repair solution ..until then i,m buing nec.for replacing ...please waiting phones...
nenmobil
Zulea not Pkey killer but He is phone killer Mr.3. Nokia Base Band 5 ( BB-5 ) 0 04-11-2009 16:02
does possible to unlock nec e228 via usb data cable with nec code reader or crazzy sw syms NEC 0 02-23-2008 19:26
URGENT URGENT : code for Furious NEC code reader metouia NEC 1 09-21-2004 16:59
NEC code reader/imei and LG Invisible Main Sales Section 0 03-12-2004 18:57
****NEC CODE READER*** 221i, 22i, 223i, 341i SOON****** FuriouS TeaM Main Sales Section 0 02-19-2004 20:02
Page generated in 0.37730 seconds with 11 queries
