06-14-2006, 11:10 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: Greece Thessaloniki
Member: 282530 Status: Offline Thanks Meter: 20 | Wintesla Not Working |
06-14-2006, 16:42 | #3 (permalink) | |
No Life Poster Join Date: Aug 2002 Age: 57
Member: 14515 Status: Offline Sonork: 100.77248 Thanks Meter: 15 | Quote:
BR Roy | |
06-14-2006, 17:40 | #4 (permalink) | |
Member: 282530 Status: Offline Thanks Meter: 20 | Quote:
not working and i have the same problem( i have experience with original Nokia Fls4) | |
06-15-2006, 09:32 | #6 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Greece, Veroia Age: 45
Member: 68628 Status: Offline Thanks Meter: 7 | Did you try to throw your box to the wall? (I'm just kiding...) I have the exact same problem. Wintesla is not working (to be exact is not finding the phone) but Phoenix is working just fine. Did anyone else experienced the same problem? I have PBB2... when i use USB connection BlackBoxTool_v70 finds it but on LPT nothing... @ZULEA please give a solution.... |
06-15-2006, 09:38 | #7 (permalink) | |
Did u choose FLS-X device in the menu? Sorry I am not at home to check it... After a few hours I am going to go home to check it and post u a screenshot... One more thing. For correct working you have to you COM port 1, 2, 3 or 4 in the FLS Virtual port and maybe you have to connect your box to the LPT port. I'll check via USB too. BR Roy | |
06-15-2006, 10:26 | #8 (permalink) | |
Member: 68628 Status: Offline Thanks Meter: 7 | Quote:
I was working for 4 years with Wintesla and original FLS-4s (and Fls-2 before they change it) and i know all the procedure of installing and using wintesla... With LPT connection as i said before my PBB2 doesn't see the box at all (as it doesn't exist), but with USB all ok. It works fine with Phoenix (i flashed many phones) but with Wintesla i installed it checked the connections (and other types of connections), i have checked the FLS-X box but NOTHING... I hope you have a solution... | |
06-15-2006, 10:29 | #9 (permalink) | |
BR Roy | |
06-15-2006, 13:03 | #10 (permalink) | |
How much Volt you use to feed the Dongle? I use 9V regulator... | |
06-15-2006, 17:09 | #12 (permalink) |
Member: 68628 Status: Offline Thanks Meter: 7 | OK i had some small progress... I found that using a usb to LPT doesn't work... I used a LPT connection to my box but when i was opening BlackBox Tool v70 it said to me that "PBB2 not found", but when i used BlackBox Tool v60 it saw the box. Then i tryed to use wintesla with the LPT connection and...... NOTHING. The exact same problem: My PBB2 doesn't see any DCT3 phone when i use Wintesla... |
06-15-2006, 20:53 | #13 (permalink) | |
PBB not work :( 1st day not work | todoportable | Phoenix Black Box | 23 | 08-05-2005 11:56 |
pls help me wintesla not working! | babaphone | Phoenix Black Box | 4 | 06-04-2005 13:07 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
wintesla doesnt work | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 14:51 |
