Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > powerflasher
Old 08-23-2005, 04:51   #1 (permalink)
lix_DAVAO's Avatar
Member: 144091
Wink 2300 after flash no signal
2300 1st flash good signal but few days later signal was loss, reflash and signal appeared a few seconds and then dropped, now reflash a many times yet signal can't make anymore.
I used PF box
PLZ help
THANX!!!
Old 08-23-2005, 05:19   #2 (permalink)
livewirecebu's Avatar
Member: 15652
bro, if dropping signal, then i think you need to start opening your phone and do hardware thing. PA perhaps.
Old 08-23-2005, 05:29   #3 (permalink)
Member: 50772
just try this pm file.......
Old 08-23-2005, 05:36   #4 (permalink)
Member: 15652
dropping signal and no signal are 2 different problems.
Old 08-23-2005, 05:51   #5 (permalink)
lix_DAVAO's Avatar
Member: 144091
before or 1st flash signal is ok but few days later from boot signal will drop in seconds and never back again,
i reflash, same symtom
my last reflash, signal won't appear anymore
and flash a many times...still none
Old 08-23-2005, 06:04   #6 (permalink)
Member: 138809
Sonork: 100.99886
hello man
if u r using powerflasher or ufs then reflash phone with same ver that it was on before, MCU + PPM , then go on the top of dctx and slect normal mode ur phone will be on with cale now slect click on PM and insert RH-18-pm file,
and then look in ur window right side down there is a button WR- PM
click it and urpm will be written,
After that do full ui-settings and check phone
it will be ok
WBR
SHAHJEE
Old 08-23-2005, 06:30   #7 (permalink)
.:bono:.'s Avatar
Member: 96141
i thing also that you phone has not charging probleme, if yes surely you have eeorom probleme, all tha guys have right.
if the 1100 pm doesn't work use this one
Old 08-23-2005, 06:31   #8 (permalink)
lix_DAVAO's Avatar
Member: 144091
it will be ok
WBR
SHAHJEE
i followed your procedure, but while writing pm it prompted me that an error occured while writing pm and ask if ill continue.
Old 08-23-2005, 06:39   #9 (permalink)
.:bono:.'s Avatar
Member: 96141
erase all the flash then flash mcu, ppm, and don't forget the pm
Old 08-23-2005, 06:59   #10 (permalink)
lix_DAVAO's Avatar
Member: 144091
THANKS for all your help my problem is solved, 2300 signal is now 100% working. pm prob indeed.
more power to gsm forum!!!
5210 v5.13 after flashing no signal lelan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 04-23-2007 20:27
2300 after flash no signal lix_DAVAO Nokia Digital Core Technology 4 ( DCT-4 ) 5 09-05-2005 20:21
2300 after flash no power djyash Griffin 0 09-01-2004 21:17
7250 After Flash no signal ... VK Griffin 6 03-04-2004 08:18
9210 after flashing no signals *Overseasunlock* Griffin 7 01-12-2004 21:39
Page generated in 0.33633 seconds with 12 queries
