02-20-2006, 22:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Nigeria Age: 42
Member: 68752 Status: Offline Thanks Meter: 88 | Activation code not working after changing serial no I have two Ufsx boxes, one is not good and i removed the long IC in the spoilt one and fixed it in the good box. after diagosing, i changed the serial no using the diagnostic tool. when i replaced the original IC, the good box now started demanding for activation string. whenever i enter the activation, it will refuse to activate. Pl's can someone tell me what to do????????? Thanks in advance |
02-25-2006, 23:24 | #3 (permalink) |
Member: 68752 Status: Offline Thanks Meter: 88 | i calculated new string for trhe old serials but it refused to activate unless i changed the serials to 5xxxx and below series before the activation will take place. also with the new serial no, the box will indicate tornado series and will not be able to flash higher model of Nokias like 3650. pl,s can someone tell me what to do?????????????? |
Nokia N73 music edition keys not working after changing the debranding code using NSS | pistachio9 | Nokia Hardware & Hardware Repair | 1 | 08-29-2009 14:30 |
nokia 6681 keypad not working after changing ic | raviuttam | WD2 & APE (Symbian Phones) | 5 | 08-07-2009 08:58 |
2600c keypad not work up key,downkey,optionskey,cencelkey not work after change ic. | lavkey | Nokia Hardware & Hardware Repair | 1 | 08-08-2008 16:52 |
iTunes not working after change flash IC | andypaijo | Motorola Hardware Repair | 0 | 01-28-2007 13:53 |
8910 mic not working after changing flexi cable | smartfone | Nokia Hardware & Hardware Repair | 5 | 10-09-2005 07:04 |
