Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > powerflasher
Old 10-05-2005, 17:31   #1 (permalink)
Member: 133351
nokia dku-2 cable problem
hi,
I try to use the nokia dku-2 cable , but when i insert it in the usb , i get device not recognized!!! there is problem and cant use it. I have windows XP SP 1 and try to use it with nokia data suite.
Any help?
i even donwloaded the xp drivers but still no luck
Regards
Old 10-05-2005, 21:55   #2 (permalink)
1ck
Member: 171091
have you installed nokia pc suite corectly( available on cd rom or nokia.com) and try installing sp2 from windows. maybee check your usb2 drivers are in use in the my computor/system information/hardware/device manager section. when i first plugged in a bluetooth dongle in usb i had a nightmare configuring it with nokia pc suite, but it just takes time and a lot of ******* about. hope i helped a bit
Old 10-06-2005, 13:58   #3 (permalink)
Member: 133351
yes i installed nokia pc suite the latest version. Do i really need sp2????? usb drivers are ok on my system. i really am getting pissed by this cable
Thanks
regards
Old 10-06-2005, 17:03   #4 (permalink)
systemworm's Avatar
Member: 68498
It is surely usb problem.Have you tested cable on another computer???
Old 10-07-2005, 13:54   #5 (permalink)
Member: 133351
No not tested on other computer , will do that and post results.
If it was usb problem? would other devices work on that usb port?because even powerflasher master works on that port
Regards
Old 10-07-2005, 15:22   #6 (permalink)
Member: 133351
I tested it on another pc running xp sp 1...Still the same problem , i downloaded nokia suite latest version , which installs drivers , but still has same problem ........Device not recognized...anyone else? Where are drivers i need? i donwloaded from nokia site, are those no good? OR IS THE CABLE JUST FAULTY (allready opened it , could see no fault!!!)
regards
Old 10-07-2005, 15:58   #7 (permalink)
sanjeewa57's Avatar
Member: 170619
dude fist you download driver soft by serching net
Old 10-07-2005, 17:04   #8 (permalink)
Member: 133351
yeah i installed drivers , but i got the problem now , it seems like nokia 3100 cant be used with dku 2 cable , so thats the whole ****....regards and thanks
Old 10-09-2005, 19:06   #9 (permalink)
systemworm's Avatar
Member: 68498
I think your cable is malfunctioned and windows doesn't recognize it
Old 10-13-2005, 02:36   #10 (permalink)
Member: 152719
you cable not very good quality..if you need good quality,pls go to under purchases.
www.smart-fans.com/item.htm
Nokia DKU-2 Cable Pin-Out Senifoto Chinese Miracle & PinFinder 1 02-05-2008 22:40
Nokia 6310i & DKU-5 or DKU-2 Cables alfmyk Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-06-2004 16:17
Nokia DKU-2 Cable, The Repair Shop Twisterflasher 3 02-19-2004 00:31
Page generated in 0.41924 seconds with 11 queries
