12-23-2004, 18:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Tips and Tricks !!! I will take exactly the words of the threads authors and also write theyr names there. In order to keep this thread ONLY technical and only hints - i will keep it closed. For any suggestions, comments and add-ons, please contact me on PM or post in this section. best regards, gobi |
12-23-2004, 19:02 | #2 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Language packs: LP: [0003] ------------------ US English Canadian French American Spanish Brazilian Portuguese LP: [0004] ------------------ UK English Standard French Standard German Standard Italian LP: [0005] ------------------ UK English French German Dutch LP: [000B] ----------------- UK English Norwegian Danish Swedish LP: [000C] ------------------ UK English Estonian Swedish Finnish LP: [000A] ------------------ UK English Spanish Portuguese Greek LP: [000E] ------------------ UK English Polish Czech Slovak LP: [004D] ------------------ UK English Complex Chinese Simplified Chinese LP: [000E] ------------------ UK English Polish Czech Slovak LP: [000F] ------------------ UK English Turkish Bulgarian Hungarian LP: [0010] ------------------ UK English Serbian Slovenian Croatian LP: [0011] ------------------ UK English Russian Romanian German LP: [0014] ------------------ UK English Chinese Complex LP: [0015] ------------------ US English Chinese Simple LP: [0016] ------------------ US English Chinese Complex LP: [0019] ------------------ UK English Portuguese LP: [001A] ------------------ UK English Spanish Portuguese LP: [001B] ------------------ American English Canadian French American Spanish LP: [0021] ---------------------- UK English Malasian Tieng Viet Thai Vietnamese Bahasa LP: [0024] ------------------ UK English Simplified Chinese LP: [0025] ------------------ UK English Magyar Polski cestina LP: [002C] ------------------ UK English Danish Swedish Norwegian Finnish German Russian LP: [002D] ------------------ UK English Estonian Latvian Lithuanian Finnish Polish Russian LP: [002E] ------------------ UK English German Russian Ukrainian French Spanish Portuguese LP: [002F] ------------------ UK English Hungarian Polish Czech Slovak Slovenian Croatian LP: [0031] ------------------ UK English Greek Romanian Bulgarian Italian German Russian LP: [0032] ------------------ UK English French Arabic German Russian Spanish Turkish LP: [0033] ------------------ UK English French Hebrew Arabic Russian Spanish Turkish LP: [0034] ------------------ UK English French Urdu Farsi Arabic Russian Spanish LP: [0034] ------------------ UK English Swedish Romanian Polish Hungarian Greek LP: [0036] ------------------ UK English Danish Polish Russian Slovak LP: [0035] ------------------ UK English Swedish Romanian Polish Hungarian Greek LP: 0037 ---------------- UK English German Dutch Polish Hungarian Czech Croatian LP: [0038] ------------------ UK English French German Italian Spanish Turkish Greek LP: [0039] ------------------ UK English French German Italian Spanish Dutch Turkish Portuguese |
The Following User Says Thank You to Gobi For This Useful Post: |
12-23-2004, 19:08 | #3 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | Installation errors and Installation error messages: - In Windows XP if you get ''Privileged Instruction" - this means you have not installed correctly or not at all the USERPORT Check TotalMoto Manual for this/ - In Windows 98 if your software is starting but it is not detecting any phone - this means you have a USB driver conflict with the ''Motorola Flash Interface'' driver (you can check in Device Manager). Solution: Install manually this driver: http://forum.gsmhosting.com/vbb/showthread.php?t=177940 - - However most easy installation is in WinXP. If you are doing it as described in manual- then 99% you can be sure you will succeed from first try. - ALLWAYS Try to put the phone in Flashmode when connecting to TotalMoto. Then the PC and TotalMoto will recognise the phone as ''Motorola Flash Interface'' and you can do fast your job. The TotalMoto software can work also if the phone is Powered on, but the PC will ask you to install about 5 drivers (all are in c:/program files/motorola/pst) and you will loose time with this. Last edited by Gobi; 12-30-2004 at 20:17. |
12-23-2004, 19:18 | #4 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | C350 - C350L specific operations and tips&tricks If you have a C350 phone and try to flash it without success then read this: Usually on many C350L if you will check on the label under the phone battery it will be written C350. So lot of people will try to flash/unlock C350L as C350 and will need this info. If you try to flash a C350L like C350 this then you will get a flashing error or the erase bar will go on and on and not end. So you have to: - take out battery, let the phone connected to the USB cable - keep * and # pressed and put battery on the phone --> if still the phone is not in Flash mode = the buttons in the software are not active, then press also now the power on button - Well now with phone model C350L selected and C350L flashfile, just flash the phone and all will be ok. - Also in some verry few cases it has helped to install the Motorola Flash Interface driver like described in the post before. |
12-30-2004, 20:34 | #5 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | When TotalMoto software start and fast shutdown: When TotalMoto software start and fast shutdown: - check if PBK file is in the c:/program files/motorola/totalmoto directory - ONLY 1 PBK file (with same serial like the LPT dongle) must be in thar directory. - check and if necessar adjust LPT port settings: ECP adress: 378h IRQ: 7 regards, Gobi |
Cell Phone Tips and Tricks - Students and Cell Phones | murtaza_nns | Off Topic Zone | 3 | 10-05-2009 21:59 |
My tips and tricks and questions for N73 6280 etc | pearsonjohnboy | BB5BOX | 7 | 03-06-2008 14:58 |
Ah no, its dummy S40 phone and unfortunately S60 tip and trick doesn’t works on that | apocalypso | Nokia Base Band 5 ( BB-5 ) | 0 | 06-25-2007 14:05 |
9210 Tips and Trick #1 and #2 | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-26-2001 02:26 |
