Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2004 Age: 28
Member: 81931 Status: Offline Thanks: 59
| V3 unlock problem. TOTALMOTO team, GOBI i got 1 V3 need to unlock. SO i follow GOBI V3 and V550 Unlock INSTRUCTIONS: V3 and V550 Unlock INSTRUCTIONS: the problem is i cant unlock i follow the INSTRUCTIONS Here are the steps on how to unlock this phones: Short manual (it's not final v3 solution) 1*. - connect phone and press 'Deactive' button... - wait message 'Reconnect miniUSB cable...' - disconnect miniUSB cable from phone and connect it again after second (or few second, no matter) - wait for process will be finished *- after thist step (1) You cant PowerOn phone untill You flash it 2**. Flash phone with Your flash file **- You can make only SLZ BackUp before flashing... Other functions may be possible after flashing... 3. Now You can make unlock or BackUp or restore BackUp 4. Press 'Upgrade' button, That's all Your phone is ready to work... ------------------------------------------------------------------------- 1. i connect phone and press 'Deactive' button... i wait message 'Reconnect miniUSB cable...' i disconnect miniUSB cable from phone and connect it again i wait for process will be finished 2. i Flash the phone. by press the REPAIR/UPGRADE buton after done i press reset subsidy 3.then press upgrade button.. DONE then check info... my phone version doesnt change any. still the old version. so i put sim and test. is same. subsidy code MR GOBI,TOTALMOTO team can u help to unlock my V3??????? MR GOBI. i saw at other reseller total moto already got the FINAL SOLUTION for V3... what is that?? |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2001 Location: GSM-TOOL Age: 41
Member: 6328 Status: Offline Thanks: 1
| I think i know where is the problem: BEFORE YOU PRESS the ''Reset Subsidy'' button, just moove the SLZ backup for the phone you want to unlock from the SLZ folder: In c:/programfiles/Motorola/TotalMoto/SLZ folder --> please moove the SLZ for your V3 from there in another directory. If it is more easyer, just moove all files from there in another directory. (I sayed MOOVE THEM, because this security backups you may need them) Now, when you will press ''Reset Subsidy'' button, the phone will be unlocked . Generally if you try to unlock any phone that has the SLZ bacup in that specific folder --> then the software will try again to make the same backup there and will abort unlocking. regards, Gobi PS. About ''FINAL SOLUTION for V3... what is that?'' - give me a link where you have seen that ... |
| | #3 (permalink) |
| Phone found... Sending RAM downloader... Phone found... BOOT version: 0007E0 SW info: R374_G_0E.40.9AR:GSMV3xxT674SP0A9 Code group versions: CG 0x 0: 0E40 CG 0x 1: 0E40 CG 0x 3: 0E40 CG 0x 4: 0E40 CG 0x 6: 0002 CG 0x15: 00B1 --- no more CG founded --- MSN: 0BFD10600A030726DED600000000F002 Checking RAM... Saving: C:\Program Files\Motorola\TotalMoto\SLZ\0BFD10600A030726DED60 0000000F002.slz Backup OK... Cant unlock... Maybe already unlocked? ok now. i already move the SLZ to other directory and i press RESET SUBSIDY. but still locked??? |
| | #4 (permalink) | |
| Quote:
MOOVE that files JUST BEFORE pressing the ''Reset subsidy'' button. regards, Gobi | |
| | #5 (permalink) |
| i already move ALL THE FILE from that directory. now showing Saving: C:\Program Files\Motorola\TotalMoto\SLZ\0BFD10600A030726DED60 0000000F002.slz Backup OK... Cant unlock... Maybe already unlocked? but my phone still locked.. thanks MR GOBI for help |
| | #6 (permalink) |
| Try again to repeat all steps -- and mooving the SLZ file out there before pressing ''Reset Subset'' button. Allways keep save THE FIRST SLZ backup that was made for that phone. This is like the Teh zone for Alcatel in matter that if any problems you need this FIRST MADE BACKUP to recover the phone. regards, Gobi |
| | #8 (permalink) |
| ok i flash with step by step. but after flash phone. my phone still old version. this means TOTALMOTO doesnt flash it????? my step is 1. click on deactivate button 2.open file C:\Program Files\Motorola\TotalMoto\Flashes\v3_0e40_lp_39\v3_ 0e40_lp_39.tmf 3.wait for message UNPLUG MINI USB. so i unplug phone ans plug again. once i pulg in. nothing happen. 4. i flash my phone using button repair/upgrade 5.after few minute done. Phone found... Sending RAM downloader... Checking RAM... Erasing... Erase complete... Uploading SW... Write complete... Mobile swithes OFF... 6. after this why my phone can NORMAL ON??????? somebody told me should be cannot b4 pressing the last step UPGRADE button 7.i on the phone make connected , i clear the SLZ folder and press reset subsidy Phone found... Sending RAM downloader... Phone found... BOOT version: 0007E0 SW info: R374_G_0E.40.3CR:SE8617AXXF104CA9 Code group versions: CG 0x 0: 0E40 CG 0x 1: 0E40 CG 0x 3: 0E40 CG 0x 4: 0E40 CG 0x 6: 0002 CG 0x15: 00B1 --- no more CG founded --- MSN: 26D40B601215072607BC00000000F002 Checking RAM... Saving: C:\Program Files\Motorola\TotalMoto\SLZ\26D40B601215072607BC0 0000000F002.slz Backup OK... Cant unlock... Maybe already unlocked? Mobile swithes OFF... 8.mobile going off. so i press on again . last step i press upgrade button Phone found... Sending RAM downloader... Checking RAM... Erasing... ERROR erasing!!! Mobile swithes OFF... (this step sometime can sometime showing error) 9. Done this all ... my phone version still remaining the old version. does change!!!! |
| | #9 (permalink) |
| Seems indeed your phone is also not getting flashed ... Try also to install the TotalMoto on another PC, or try to use a USB hub with esternal Power. regards, Gobi |
| | #10 (permalink) |
| i try intall on my notebook but getting error PRIVATE INSTRUCTION. even i install the user port and do the all setup bios LPT port... but no use also... thats why i use my PC install it. thought can work well... but now failed to unlock.. |
| | #11 (permalink) | |
| Insane Poster ![]() ![]() ![]() Join Date: Nov 2004 Location: www.TotalMoto.net Age: 42
Member: 92977 Status: Offline Thanks: 0
| 1. Give me Your SLZ backup... I need to check if its OK... Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| v3 unlock problem - interface not found | ekotek | Smart-Clip | 9 | 12-03-2007 14:02 |
| V3 unlock problem! | uffehbg | Motorola P2K (USB-Smart) | 6 | 05-02-2006 14:25 |
| v3 unlocking problem | 8210 | Smart-Clip | 2 | 01-05-2006 16:26 |
| v3 unlock problem | gaz3051 | Smart-Clip | 10 | 07-10-2005 16:42 |
| Rogers Motorola V3 Unlocking problem | nabeel7 | Smart-Clip | 2 | 03-25-2005 11:24 |
