02-21-2005, 02:08 | #2 (permalink) |
No Life Poster Join Date: Jan 2002
Member: 8379 Status: Offline Thanks Meter: 35 | Please download the update software to your pc, then unzip the file. 1)click register.bat 2)click fusion_v1.25.exe 3) click smart update ( above the right enter button ) 4) press the left button of the platinum clip when ask to. ( if need to restart, remove one battery and replace. after update you can check the software version on your clip by Device Diagnostic Modules: v4.0 Data: v2.1 Audio: v2.1 ( maybe blank ) Then for the first time after update, there will be a test for the buttons. you will need to follow the single led to press the right button then the left buttton. What's new? LG 8120 added V1.02 V1.03 V1.04 after unlock please insert different simcard, then enter 2945#*88110# , ok , ok, 00000000 Check software version: Type 277634#*# This software version have the option for you to added the extra function, please contact your reseller for price. SonyEricsson RSA option: unlock K700i K500i S700 P910 T610RSA NEW version R2Y R2AA R2AE for k700 and k500 VK option: unlock vk model 207i 530 Also for Black clip Fusion customer to upgrade to Platinum clip option For activation request, you will need to do the following Run fusion activation uploader V1.5, choose com port connect update cable to device, press the select button, wait until the leds is sweeping across, click READ DEVICE you will see for example: Reading... Device firmware: v4.0 Device ID: D8 E9 98 CD A6 C5 E0 D4 LG not activ ! VK not activ ! ERICSSON not activ ! PLATINUM FUSION ! Give your Device id to your reseller, after the payment have settle, you will received a activation string in return, copy and paste into the white box, then upload ACTIVATION when the leds is sweeping across. Enjoy!! |
how to update clip | triggerz | Vodafone Star | 4 | 08-14-2009 23:55 |
How to update clip? | shahzaadbutt | Ultimate-Sam | 9 | 08-12-2009 17:08 |
How to Update? Instructions and FAQ | to_deal_with | Smart Sam | 0 | 05-09-2007 21:32 |
What the ..... Privileged instruction while trying to update | Alkapone | SagMaster Team OLD Products | 4 | 03-12-2005 22:08 |
Does anyone have any instruction to make unlcok clips, what pic chip is used ? | STB Trading | Samsung Flashers, Software, Firmware. | 1 | 06-10-2002 06:50 |
