Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Data1 Team Products
Old 04-10-2005, 18:36   #31 (permalink)
Member: 12356
Thanks Meter: 7
Question
I've recently bought a platinum talking clip, upgraded to latest 4.1 version.
I've diagnosed and all are activated, using Brand new AA Energizer alkaline batteries.
Also i've Unlocked 7650 and reset it's lock code to 12345 with no problem.
But tried on two (2) 1100 phones, goes to local mode, clip says "ok shutdown" but phones still locked (had to use ufs to unlock instead).
Steps done:
Phone is on and connected to clip
selected Nokia -> DCT4 -> DCT4 Unlock "say's phone must be on"
pressed select twice (clip lights progesses and phone is in local mode)
clip say's "ok shutdown"
tested phone, "SIM not valid"
verified with ufs using "info" yep, still locked
Tried to test it on 5510 and 7110 security codes, i purposely changed the code to for example 11111 clip say's "ok shutdown" but security code still not resetted to 12345 instead to the code i set it to.
Steps done:
selected Nokia -> DCT3 -> DCT3 Reset security "say's phone must be on"
Phone is off and connected to clip
Turned on phone then press select
but code still not resetted.
any ideas? Thanks.
Old 04-11-2005, 08:19   #32 (permalink)
Sweden Mobile's Avatar
Member: 90734
Thanks Meter: 3
Gx15
GX15 not supported yet!
But soon will be add in the next version I think!
D500 unlock work 1000000% with Platinum Clip.
Just go to e700, Press Enter and Power on, the phone will go to TAT mode.
Good Luck Platinum Team
Sweden Mobile
Old 04-11-2005, 08:27   #33 (permalink)
Member: 90734
Thanks Meter: 3
Upgrade
Try to upgrade it again!
I think that could happened something when upgradig, try to upgrade it again!
Sweden Mobile
Old 04-12-2005, 16:18   #34 (permalink)
Member: 12356
Thanks Meter: 7
Unhappy
I've upgraded it again and again but still the same.
Reading...
Device firmware: v4.1
Device ID: (my device id )
LG ACTIVATED !
VK ACTIVATED !
ERICSSON ACTIVATED !
PLATINUM FUSION !
Diagnostics:
Modules: v4.1 Ok
Data: v2.2 Ok
Audio: v2.1 OK
i've tried on these phones and their results:
Successfull
Sony Ericsson T310 Unlock and phone code reset works 100%
Sendo m550 unlock works 100%
Samsung E715 unlock works 100%
Sharp GX10 unlock works 100%
Nokia 7650 Unlock and lock code reset works 100%
Nokia 3650 Unlock and lock code reset works 100%
Nokia 3200 Unlock and security code reset works 100%
note: after security code reset some user data has been DELETED like phonebook/messages/settings/etc except gallery
Unsuccessfull
Nokia 1100 clip say's ok shutdown (phone restarts) but still locked
Nokia 3315 clip say's ok shutdown (phones restarts) but still locked
Nokia 3315 Security code clip say's ok shutdown (phones restarts) but still the same code remains
Nokia 5510 clip say's ok shutdown (phones restarts) but still locked
Nokia 5510 Security code clip say's ok shutdown (phones restarts) but still the same code remains
Nokia 7110 clip say's ok shutdown (phones restarts) but still locked
Nokia 7110 Security code clip say's ok shutdown (phones restarts) but still the same code remains
Although there are alternative ways to do the above mentioned tasks, It is quite disturbing that my brand new clip can't do the job. I tried and tried but still the same results i've checked the cables and they are 100% ok as i have a data cable that i modified to fit the clips and they are working fine with nokiatool/logomanager/dct4fbustool_by_maestro. And since the clip is supposed to be portable, this is going to be a problem.
I can't say that the clip is faulty coz it does the other jobs flawlessly. Am i the only one experiencing this type of problem?
Any ideas?
Thanks.
Old 04-15-2005, 16:35   #35 (permalink)
Member: 32127
Thanks Meter: 34
sorry got wrong posting earlier regarding sendo_620....must be at smartclip section....thanks
Old 04-16-2005, 18:08   #36 (permalink)
Member: 8379
Thanks Meter: 35
Reading...
LG ACTIVATED !
VK ACTIVATED !
PLATINUM FUSION !
Diagnostics:
Modules: v4.1 Ok
Data: v2.2 Ok
Audio: v2.1 OK
Successfull
Unsuccessfull
Any ideas?
Thanks.
This may be the 3310 cable you are using, the cable with the M BUS / F bus switch ( 3 wires inside )don't work with platinum clip, both M and F bus is require the same time, you will need a 3310 cable with 4 wires.
Old 04-16-2005, 20:07   #37 (permalink)
Member: 12356
Thanks Meter: 7
Thanks datacablelondon and greatly appreciated, that sorted out my dct3 problems I was hesitant to open up the cables coz of the warranty seals, but its just the cables so i opened them up and found out that most of my dct3 cables have 3 wires, had to mod them to four wires. Thanks again.
I havent notice this in the list so please add to list of unlocked phones:
Nokia 6510/8310 Unlocked and security code reset 100% works
Samsung D410 Unlocked and lock code reset 100% works
Failed on:
Nokia 1100 and 2300 - "communication error shutdown"; "unlock error shutdown"; fax/modem like sound with "phone type, shutdown"; "Unknown phone type, shutdown"; "ok shutdown" (but stlll locked)
cable checked with three (3) wires blue, white, and black (tx,rx,gnd) and is configured properly. Imei is not ???, is unlockable via code or tornado. Any ideas?
Observation: I noticed that in samsung phones unlocking+lock code reset usually resets the phone's default settings but no data loss (images,contacts,etc) But in nokia dct4 security code reset causes the phone phone to its dafaults with some data loss (contacts,sms,mms,settings)
Again many thanks
Old 05-06-2005, 01:37   #38 (permalink)
Member: 8379
Thanks Meter: 35
try this
http://www.data1clip.com/v42.zip
Old 05-06-2005, 02:18   #39 (permalink)
karismajaya's Avatar
Member: 42805
Thanks Meter: 16
how about v44
which art the new one?
Old 05-12-2005, 05:16   #40 (permalink)
Member: 4675
Thanks Meter: 7
lg u8130 up to what version can this clip unlock?
Old 05-13-2005, 01:50   #41 (permalink)
Member: 42805
Thanks Meter: 16
i try with LG 8138 doesn't work...
Old 05-14-2005, 04:48   #42 (permalink)
tan2x81's Avatar
Member: 57103
Thanks Meter: 32
can platinum clip unlock sahrp gx15?.... if so how?... thanks... D
Old 05-16-2005, 10:31   #43 (permalink)
pig
pig's Avatar
Member: 18965
Thanks Meter: 3
No - The PlaTinumclip Does Not Unlock The Sharp Gx15
www.platinumclip.co.uk
Old 07-08-2005, 02:07   #44 (permalink)
Member: 9584
Thanks Meter: 31
hi
i cannot use my clip at all. i cannot select the phone models with select button. it always says sony ericsson old model . can somebody write a good manual here .on my clip there is no menü button only enter and select
Old 07-08-2005, 08:59   #45 (permalink)
pig
pig's Avatar
Member: 18965
Thanks Meter: 3
go here! www.platinumclip.co.uk - download the new v4.5 software into your platinumclip and see what happens! also there is a manual on there!
Smart-Clip Team Need Your Help about V9 Unlocking with Smart-clip TP ........ ZoHaiB_(FoneGSM) Smart-Clip 2 06-23-2008 15:59
lg 8110 unlock with platinum clip help James-R LG 0 03-10-2005 20:18
failure to unlock k700i and z1010 with platinum clip reignsmart Data1 Team Products 7 02-13-2005 11:39
Siemens C60 unlock with Siemens Clip? Falck Griffin 1 09-29-2003 06:47
can 9110 be unlocked with dct3 clip? -=KnOeFz=- Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-13-2002 07:40
Page generated in 0.36332 seconds with 10 queries
