04-10-2005, 18:36 | #31 (permalink) |
Insane Poster Join Date: May 2002 Age: 46
Member: 12356 Status: Offline Thanks Meter: 7 | I've diagnosed and all are activated, using Brand new AA Energizer alkaline batteries. Also i've Unlocked 7650 and reset it's lock code to 12345 with no problem. But tried on two (2) 1100 phones, goes to local mode, clip says "ok shutdown" but phones still locked (had to use ufs to unlock instead). Steps done: Phone is on and connected to clip selected Nokia -> DCT4 -> DCT4 Unlock "say's phone must be on" pressed select twice (clip lights progesses and phone is in local mode) clip say's "ok shutdown" tested phone, "SIM not valid" verified with ufs using "info" yep, still locked Tried to test it on 5510 and 7110 security codes, i purposely changed the code to for example 11111 clip say's "ok shutdown" but security code still not resetted to 12345 instead to the code i set it to. Steps done: Phone is on and connected to clip selected Nokia -> DCT3 -> DCT3 Reset security "say's phone must be on" clip say's "ok shutdown" Phone is off and connected to clip selected Nokia -> DCT3 -> DCT3 Reset security "say's phone must be on" Turned on phone then press select clip say's "ok shutdown" but code still not resetted. any ideas? Thanks. |
04-11-2005, 08:19 | #32 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 41
Member: 90734 Status: Offline Thanks Meter: 3 | Gx15 GX15 not supported yet! But soon will be add in the next version I think! D500 unlock work 1000000% with Platinum Clip. Just go to e700, Press Enter and Power on, the phone will go to TAT mode. Good Luck Platinum Team Sweden Mobile |
04-12-2005, 16:18 | #34 (permalink) |
Member: 12356 Status: Offline Thanks Meter: 7 | I've upgraded it again and again but still the same. Reading... Device firmware: v4.1 Device ID: (my device id ) LG ACTIVATED ! VK ACTIVATED ! ERICSSON ACTIVATED ! PLATINUM FUSION ! Diagnostics: Modules: v4.1 Ok Data: v2.2 Ok Audio: v2.1 OK i've tried on these phones and their results: Successfull Sony Ericsson T310 Unlock and phone code reset works 100% Sendo m550 unlock works 100% Samsung E715 unlock works 100% Sharp GX10 unlock works 100% Nokia 7650 Unlock and lock code reset works 100% Nokia 3650 Unlock and lock code reset works 100% Nokia 3200 Unlock and security code reset works 100% note: after security code reset some user data has been DELETED like phonebook/messages/settings/etc except gallery Unsuccessfull Nokia 1100 clip say's ok shutdown (phone restarts) but still locked Nokia 3315 clip say's ok shutdown (phones restarts) but still locked Nokia 3315 Security code clip say's ok shutdown (phones restarts) but still the same code remains Nokia 5510 clip say's ok shutdown (phones restarts) but still locked Nokia 5510 Security code clip say's ok shutdown (phones restarts) but still the same code remains Nokia 7110 clip say's ok shutdown (phones restarts) but still locked Nokia 7110 Security code clip say's ok shutdown (phones restarts) but still the same code remains Although there are alternative ways to do the above mentioned tasks, It is quite disturbing that my brand new clip can't do the job. I tried and tried but still the same results i've checked the cables and they are 100% ok as i have a data cable that i modified to fit the clips and they are working fine with nokiatool/logomanager/dct4fbustool_by_maestro. And since the clip is supposed to be portable, this is going to be a problem. I can't say that the clip is faulty coz it does the other jobs flawlessly. Am i the only one experiencing this type of problem? Any ideas? Thanks. Last edited by Vinny_xel; 04-13-2005 at 20:22. |
04-16-2005, 18:08 | #36 (permalink) | |
No Life Poster Join Date: Jan 2002
Member: 8379 Status: Offline Thanks Meter: 35 | Quote:
This may be the 3310 cable you are using, the cable with the M BUS / F bus switch ( 3 wires inside )don't work with platinum clip, both M and F bus is require the same time, you will need a 3310 cable with 4 wires. | |
04-16-2005, 20:07 | #37 (permalink) |
Member: 12356 Status: Offline Thanks Meter: 7 | Thanks datacablelondon and greatly appreciated, that sorted out my dct3 problems I was hesitant to open up the cables coz of the warranty seals, but its just the cables so i opened them up and found out that most of my dct3 cables have 3 wires, had to mod them to four wires. Thanks again. I havent notice this in the list so please add to list of unlocked phones: Nokia 6510/8310 Unlocked and security code reset 100% works Samsung D410 Unlocked and lock code reset 100% works Failed on: Nokia 1100 and 2300 - "communication error shutdown"; "unlock error shutdown"; fax/modem like sound with "phone type, shutdown"; "Unknown phone type, shutdown"; "ok shutdown" (but stlll locked) cable checked with three (3) wires blue, white, and black (tx,rx,gnd) and is configured properly. Imei is not ???, is unlockable via code or tornado. Any ideas? Observation: I noticed that in samsung phones unlocking+lock code reset usually resets the phone's default settings but no data loss (images,contacts,etc) But in nokia dct4 security code reset causes the phone phone to its dafaults with some data loss (contacts,sms,mms,settings) Again many thanks Last edited by Vinny_xel; 04-18-2005 at 17:43. |
07-08-2005, 02:07 | #44 (permalink) |
No Life Poster Join Date: Feb 2002 Location: germany Age: 49
Member: 9584 Status: Offline Thanks Meter: 31 | hi i cannot use my clip at all. i cannot select the phone models with select button. it always says sony ericsson old model . can somebody write a good manual here .on my clip there is no menü button only enter and select |
07-08-2005, 08:59 | #45 (permalink) |
No Life Poster Join Date: Dec 2002 Age: 56
Member: 18965 Status: Offline Thanks Meter: 3 | go here! www.platinumclip.co.uk - download the new v4.5 software into your platinumclip and see what happens! also there is a manual on there! |
Smart-Clip Team Need Your Help about V9 Unlocking with Smart-clip TP ........ | ZoHaiB_(FoneGSM) | Smart-Clip | 2 | 06-23-2008 15:59 |
lg 8110 unlock with platinum clip help | James-R | LG | 0 | 03-10-2005 20:18 |
failure to unlock k700i and z1010 with platinum clip | reignsmart | Data1 Team Products | 7 | 02-13-2005 11:39 |
Siemens C60 unlock with Siemens Clip? | Falck | Griffin | 1 | 09-29-2003 06:47 |
can 9110 be unlocked with dct3 clip? | -=KnOeFz=- | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-13-2002 07:40 |
