Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Data1 Team Products
Old 01-21-2005, 21:57   #1 (permalink)
X-Shadow's Avatar
Member: 871
SPV Unlocking
Hi,
What versions of SPV and SPV E100 phones does the Talking Clip support?
I have successfully unlocked E100 v1.13 in around 45 seconds ;-)
However, is it safe to modify the clip such that it would accept 6v external
power instead? I am concerned because my customers might kill the phone
when batteries fail. I am telling my customers to always use Energizer Alakline
batteries and avoid using cheap batteries... but since there is not battery
"LOW" indicator, how will they know when to change the batteries?
I have to say that I find this product very stable in unlocking SPVs!!
I have some minor problems in Samsung phones though,, hard to determine
which unlock function to use for a specific model which is not listed in
your text file.
Best Regards,
X-Shadow
Old 01-22-2005, 02:54   #2 (permalink)
Member: 3526
Hi X-Shadow,
The device is designed to run on AA or AAA batteries, you can flick down a paddle inside, to make it take AAA batteries.
In regards to using and external power source, I am sure you can try something, but the device is designed so it needs power from each and every one of the batteries, so you may have some issues doing so.
There is a battery low indicator, because when the device is low in battery it doesn't have enough power the ic that runs the voice properly, so rather than talking, the clip just will make a noise like a tv not tuned in properly.
What are the samsung phone you are reffering to?
If you are referring to the Samsung E800 or E700, then you must have the phone off with the battery attached and disconnected from the cable, select the phone in the menu and then when it says the phone must be off and the lights start flashing like a christmas tree then you plug the phone in.
Best Regards
Saejor
Data1Clip Team
Old 04-10-2005, 02:48   #3 (permalink)
Member: 4675
i can't unlock my spv, always communication error, am i connecting the cables right? mini usb to ps2, ps2 to serial female, serial male to spv. am using new batteries.
Old 04-10-2005, 18:50   #4 (permalink)
Member: 12356
please check:
1. Make sure that you are in canary mode (bootloader mode/tri-color)
2. Clip connected to usb->ps2, ps2->serial, serial->spv
3. Clip has sufficient/new batteries
4. Spv cable has 9V Battery connected
5. You've selected SPV in clip
6. After "phone must be on" you've pressed the select key on clip
Hope this helps.
Old 04-11-2005, 14:18   #5 (permalink)
Member: 4675
problem sorted out, i'm on XDA menu, thought they are the same as SPV, since same manufacturer. ;-)
Old 04-17-2005, 11:47   #6 (permalink)
Member: 122339
i need to unlock my smart amazing II also,
Need help
br
jache
Old 06-19-2005, 21:52   #7 (permalink)
Member: 53039
SPV Unlock Problem with Talking Clip
Recently attempted to unlock the spv e100 with the platinum talking clip & after it said done & i reset the phone it will only boot on the canary screen (press any key for bootloader)
Can't get the phone to boot up at all now, anyone have any suggestions?
Thanks in advance
Old 10-12-2006, 04:52   #8 (permalink)
john_john's Avatar
Member: 310833
how to hard reset spve100
***SPV Unlock without SPV-Services*** c500-c550-c600 mustipusti HTC & Smartphones ( WM Without Touch) 27 08-22-2011 19:09
original SPV unlock? nadger Various 14 02-08-2004 00:15
Orange SPV unlock code Raklm Phone Unlocking Codes & Maps 1 09-19-2003 01:21
Spv Unlock sams Various 2 07-19-2003 20:04
Orange Spv?? Unlock Anyone??? unlockgod Various 0 11-23-2002 23:10
Page generated in 0.35636 seconds with 11 queries
