06-29-2005, 08:42 | #1 (permalink) |
Junior Member Join Date: Mar 2005 Age: 64
Member: 124317 Status: Offline Thanks Meter: 0 | k300i died after unlocking Tried recover phone, anyhelp please reply asap, if any special flash file required let me know. Thanks |
06-29-2005, 10:14 | #2 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: Guangzhou, China
Member: 38039 Status: Offline Thanks Meter: 6 | Quote:
You are using the lastest Sonics version 1.105, aren't you? If the answer is no, please use the latest version, if yes, copy and post log here. best regards | |
06-29-2005, 12:07 | #3 (permalink) |
Member: 124317 Status: Offline Thanks Meter: 0 | Hi Thanks for the quick reply it is K300i and I used the v1.105 Powering phone.... Chip Id: Ox8000 CID detected: 36 Phone color: RED Speed: 115200 bps Header acknowledged. Prologue acknowledged. Payload acknowledged. RECOGNIZED PHONE TYPE: f500/k500/k700 OTP status: 0, locked: 1, CID: 36 PAF: 1, IMEI: 35579500219847 Phone needs to be completed now...... Time elapsed: 16 secs This message after doing the recover phone and flashfiles |
06-30-2005, 08:45 | #4 (permalink) |
Member: 38039 Status: Offline Thanks Meter: 6 | @aacs I found that you didn't select any firmwares for flashing your K300i, you'd select firmwares first, the speed could be 921600bps. After flashing, unlock phone. best regards |
06-30-2005, 09:41 | #5 (permalink) |
Member: 124317 Status: Offline Thanks Meter: 0 | Hi Yes you are right I am having problem downloading from your site can you please let me know the exactly falshing file I need, great job redeagle well done, please let me know Thanks again |
07-01-2005, 01:24 | #7 (permalink) | |
Copy and post log here, i'll try to help you. best regrads | |
07-01-2005, 01:33 | #8 (permalink) | |
The attached file include language info of firmwares. | |
07-02-2005, 04:15 | #9 (permalink) |
Member: 124317 Status: Offline Thanks Meter: 0 | Hi Thanks for your support I did download the firmware K300i_Red36_R2AT003_EU_EMEA5_Fs.bin.snx and falshed the phone But when flashing a message come up below SSW uses dynamic hash, dynamic hash len is: 73 Going to flash 73 blocks ... Err when get answer : worthless answer , expect 0x89. superblock not accepted. Thanks |
07-02-2005, 10:38 | #10 (permalink) | |
best regards | |
07-03-2005, 08:09 | #11 (permalink) |
Member: 124317 Status: Offline Thanks Meter: 0 | Hi Redeagle Good news, all worked fine, flashed with the main firmware after I did recover phone 36 and the phone now back to life, thanks for your support keep the good work, the sonyericsson k300i Red cid 36 worked beautifull within seconds, but one problem it tooked me to download firmware from your site 2 days kept trying finally sucsessfull, Thanks again |
07-03-2005, 16:13 | #12 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | Redeage ur site is very slow to downloading flash files many times its missing only some kb or give us other good working link Br Kuku |
07-16-2005, 05:27 | #13 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Philippines Age: 55
Member: 43404 Status: Offline Thanks Meter: 19 | Good Day to all... I got the same problem here, after i unlocked k300i the phone went dead. At first i was trying to recover the phone then it says UNKNOWN PHONE, and it suggests to RECOVER PHONE, which i did, and i used cid36 which unlock the phone quickly, but after that it went DEAD. i used 1.16v of sonics. it says something about the phone is RED then the unlocking process i think makes the phone BROWN, which eventually made it DEAD. But before unlocking i made a GDFS backup, but when the i try to put it back it's still dead... CAN YOU HELP ME WITH MY PROBLEM PLEASE.... WHAT SHOULD I DO? WILL I FLASH IT WITH BROWN OR RED? IF THIS IS FOR RED (K300i_Red36_R2AT003_EU_EMEA5_Fs.bin.snx) THEN WHAT FLASH FILE IS FOR BROWN? I would be very greatful for any reply.... |
07-16-2005, 08:18 | #14 (permalink) | |
Member: 38039 Status: Offline Thanks Meter: 6 | Hi, my friend, JUST REFLASH with BROWN, will okay. After recovering phone, you need reflash phone now, there is a hint in the interactive window, but you ignored it. best regards Quote:
07-16-2005, 12:29 | #15 (permalink) |
Member: 43404 Status: Offline Thanks Meter: 19 | Yes! I made a decision and i flashed it with brown MAIN file (12m size) and now the phone is OK. THANK YOU VERY MUCH FOR THE VERY QUICK REPLY MY FRIEND..... *** BLESS TO ALL.... AS I SAID, I AM VERY GREATFUL.... |
K300i blocked after unlock... | Rasool | Sony Ericsson | 6 | 05-26-2006 20:33 |
LG C200 Die After Unlock with RedBox | Petrock | LG | 2 | 04-10-2005 16:02 |
U8120 V102 Died after unlock | blang | VygisToolbox | 8 | 12-08-2004 14:32 |
Motorola t 191 Ver 1.78 die after unlock with T191 SSW V.7.7 | guiso | Motorola ODM | 19 | 05-13-2004 10:01 |
m55 v07 died after unlock | C3aby | E-Gold Based Phones | 5 | 01-14-2004 16:00 |
