Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Banned ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Philippines Age: 42
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks: 6,376
| Failed To Open help boss how to recover my box: Verifying license... Lante Dongle #MA0165 Ready. There are 1 FTDI devices found, 0 Sonics and 1 UFSx. Failed to Open device. Verifying license... Lante Dongle #MA0165 Ready. There are 1 FTDI devices found, 0 Sonics and 1 UFSx. Failed to Open device. i have 6 ports wat is this........ thanks |
| | #2 (permalink) |
| hi sir HELLP no body answer me i cant use my sonic box rigt now. if com 1 i use is ok look my POST. |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2003 Location: Guangzhou, China
Member: 38039 Status: Offline Thanks: 0
| Hi, sir, Are you using ufs? What cable are you using? If you're using Teleway 4 in 1 or similar one, you'd determine which port it's using first, COM3, or COM4, or COM5... you can also SCAN PORT to get activated serial port. best regards |
| | #4 (permalink) |
| QUOTE=Redeagle]Hi, sir, Are you using ufs? What cable are you using? If you're using Teleway 4 in 1 or similar one, you'd determine which port it's using first, COM3, or COM4, or COM5... you can also SCAN PORT to get activated serial port. best regards[/QUOTE] << yes sir when i use SONICS CONNECT SONICS,WHEN I USE COM1 OK CANT UNDERSTAN, i would like connect sonics is OK. |
| | #5 (permalink) |
| look this ERROR SIR::Verifying license... Lante Dongle #MA0165 Ready. There are 1 FTDI devices found, 0 Sonics and 1 UFSx. Failed to Open device. Verifying license... Lante Dongle #MA0165 Ready. There are 1 FTDI devices found, 0 Sonics and 1 UFSx. Ufs Serial Number is #1841504 Invalid License String. Faild to connect to Ufs. Verifying license... Lante Dongle #MA0165 Ready. Device ready. Powering phone... Operation be canceled! Unknown phone, that's an error. Device disconnected. Verifying license... Lante Dongle #MA0165 Ready. There are 1 FTDI devices found, 0 Sonics and 1 UFSx. Failed to Open device. Connect Sonics first! Connect Sonics first! Connect Sonics first! Connect Sonics first! Connect Sonics first! Connect Sonics first! Verifying license... Lante Dongle #MA0165 Ready. There are 1 FTDI devices found, 0 Sonics and 1 UFSx. Ufs Serial Number is #1841504 Invalid License String. Faild to connect to Ufs. <<<<< I DONT KNOW WAT HAPPEN SIR>>>> Serial number: #MA0165 not a Sonics, maybe a UFO, please contact service. |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Location: Sun Age: 34
Member: 4021 Status: Offline Thanks: 832
| ur using ufs to act as comport?... u must have a valid licensed.... or u may also do this unplug ufs device and just connect ur sonics box alone... then try to connect again |
| | #7 (permalink) | |
| Quote:
<< yes sir today i already format my computer this time i install again this is the result: FOUND NEW HARDWARE: DIV UST, LANTE UFO SERIES, UFSXX . wat is it how to change UFSXX to lante sonics: | |
| | #8 (permalink) |
| [QUOTE=Redeagle]Hi, sir, Are you using ufs? What cable are you using? If you're using Teleway 4 in 1 or similar one, you'd determine which port it's using first, COM3, or COM4, or COM5... you can also SCAN PORT to get activated serial port. best regards[/QUOTE ok my box is dead so i try to connect UFSX BUT THE RESULT IS sonic box acvtivation string wat is that SIR??????????? |
| | #9 (permalink) |
| how can u say that ur box is dead??? u jst need a modified drive for your box.. use search button.. as far as i can remember it was invisble who posted for the modified driver.... jst check it... |
| | #10 (permalink) | |
| Quote:
<<< yes ser i use already MODIFIED DRIVER UFO: then i dside to back 98 but dsame wat will i do.......??????? | |
| | #11 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Nokia is Far Away from World Age: 34
Member: 70796 Status: Offline Thanks: 205
| [QUOTE=fullflash_sl] Quote:
LAT | |
| | #12 (permalink) |
| Hi, sir, as Mr. kg2004 said, check your SONICS folder or SYSTEM folder for whether an important DLL named "usbci.dll" in it, if not, copy a "usbci.dll" to your SONICS folder. best regards |
| | #13 (permalink) | |
| Quote:
>>> ok thanks today only COM 1 working, but if u connect sonics and ufsx said: ILLEGAL OPERATION. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| NS Dongle failing to open | tical | NSPRO | 5 | 05-03-2006 18:05 |
| 6600 Fails To Open.. | Mang mel | Nokia Hardware & Hardware-Repair Area | 1 | 01-16-2006 15:51 |
| c62 fail to open com port | Moosani | FuriouS II | 21 | 06-20-2005 14:17 |
| Failed to open Com Port | s7event | Panasonic | 0 | 04-23-2004 08:28 |
