Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Sonics Box
Old 07-22-2005, 11:11   #1 (permalink)
ryumahon's Avatar
Member: 4021
i killed lg 8120 by flashing....
i jst killed a LG8120 before the problem was jst blinking now its dead..... coz i dont know where to put the flashes.. what flash file must i use and where to put it... im using se1.118,
to where must i put the drive_c, drive_media. the fs_rec_uk, and the wcdma_4mbram.ssw????
i need your help!!
tnx in advance!!!!
Old 07-23-2005, 02:09   #2 (permalink)
Member: 38039
Hi,
Select LG3G page first, then click on "Add file", select all files you want, such as main, fs, drive_c, drive_media, and so on.
After that, only one thing left, just press "Flash Files".
best regards
i need your help!!
tnx in advance!!!!
Old 07-23-2005, 07:21   #3 (permalink)
ryumahon's Avatar
Member: 4021
tnx redeagle... i hope i can fix this with ur help!!! tnx!!
Old 07-23-2005, 13:30   #4 (permalink)
ryumahon's Avatar
Member: 4021
Originally Posted by Redeagle
Hi,
best regards
sir tnx for your reply now the phone is alive but the problem is, it shuts off every 5-10 secs... i tried manual format also but still the same.. what else must i do sir??
tnx alot!!
Old 07-23-2005, 14:00   #5 (permalink)
MELDON BA's Avatar
Member: 65015
Press Unlock. And All Will Be Ok
Old 07-23-2005, 14:53   #6 (permalink)
ryumahon's Avatar
Member: 4021
i did the same also but still the same... do i have to flash it with gdfs???
Old 07-23-2005, 15:23   #7 (permalink)
MELDON BA's Avatar
Member: 65015
BATTERY HAS TO BE FULLY CHARGE AND FLASH ALL 4 FILES.
HOPE YOU DID NOT HAVE A CORRUPTED FILE.
Old 07-24-2005, 07:00   #8 (permalink)
ryumahon's Avatar
Member: 4021
yes the battery is full and for sure the file is not corrupted because i downloaded it at the support site...
pls need your help..
tnx!!
Old 07-24-2005, 10:30   #9 (permalink)
MELDON BA's Avatar
Member: 65015
Do You Have The Latest Update Of Sonics Installed?
Old 07-24-2005, 11:21   #10 (permalink)
ryumahon's Avatar
Member: 4021
yep!! i used se 1.118... i need any advice if do i have to flash the gdfs... pls help
tnx a lot!
Old 07-25-2005, 02:38   #11 (permalink)
Member: 38039
yes, it's my mistake, i forgot to add a field to write gdfs file for LG3G, but it will not affect you on writing gdfs, just select page "Sony Ericsson" and write gdfs files here.
best regards
tnx a lot!
Old 07-25-2005, 05:41   #12 (permalink)
ryumahon's Avatar
Member: 4021
sir.. i flashed the phone with gdfs... but still the same... after few seconds it shuts off.. any more advice sir?? pls redeagle.. i ndeed to repair this phone...
tnx alot!
Old 07-25-2005, 08:46   #13 (permalink)
Member: 38039
Hi,
Try another version of firmwares, for example, you formerly flash phone with UK v105 firmwares, now with UK v107 or Australia v105 instead, may you good luck.
best regards
Old 07-25-2005, 11:40   #14 (permalink)
ryumahon's Avatar
Member: 4021
ok sir i will try your suggestion... i also noticed that if i hook the charger with the phone it wont shut down automatically... and if i insert the sim with charger hooked the phone wont continue to boot up to its main menu... hope by flashing with another version can solve my problem..
or can somebody pls advice if it is still software problem or possible hardware problem?
Unlock LG U300 by flash FAILED at-kom VygisToolbox 1 02-13-2010 22:49
Killed LG KE970 by direct unlock in ULT kamilmaly2004 ULT PRO 2 12-07-2007 12:43
Unlock LG U880 by flash successful but still SIM locked Naseerjako UST Pro II 6 06-17-2007 10:26
help! i killed a c62 by flashing... ryumahon NON Siemens Brand (ODM Phones) 0 09-10-2005 16:07
beware of lg 8120 with redbox it can kill ur phone ADD-GSM NEC 0 12-30-2004 11:29
Page generated in 0.33441 seconds with 11 queries
