Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Sonics Box
Old 05-08-2005, 19:46   #1 (permalink)
ashok2's Avatar
Member: 81612
Sonork: ashok2
K700i not unlocking
Hello,
I am a new user to Sonics...i tried unlocking k700i and not sucessfull...it just says powering phone and goes to 100%. I click on on button in the phone but no response.
I don't have K00i GDFS file so, i tried to read gdfs from a working phone, but same problem"powering phone". Nothing happens if i press the 'on' button in the phone.
Someone please help...
Regards.
Ashok.
Old 05-09-2005, 00:19   #2 (permalink)
Member: 2785
check if cable is in correct rj45 slot (it's the SPT - the one closer to the leds).
after pressing unlock, you must press and release the phone's power button, and everything should go fine. if don't please try on another computer, or even other usb port, as i had similar problems once
Old 05-09-2005, 01:53   #3 (permalink)
Member: 38039
Originally Posted by ashok2
Hello,
Regards.
Ashok.
Hi, sir:
My proposals:
1) make sure your SONICS version is the latest;
2) make sure your battery is fully charged;
3) make sure your cable is correct;
4) refer to the manual;
You'd power on the attached phone due to the hint runtime, if failed to power on, re-insert the battery and try again.
best regards
Old 05-09-2005, 08:52   #4 (permalink)
ashok2's Avatar
Member: 81612
Sonork: ashok2
It is unlocking
The K500i phone is now unlocking....the battery was down..
Thanks.
my black berry 8100 is not unlock (Answered) ravin j tejura MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 11 04-08-2010 15:05
K700i NOT CHARGING mobilesmith Sony Ericsson Hardware Repair Area 12 06-27-2008 01:13
k700i not light lcd and not work keys 3, 6, 9 alksander Sony Ericsson Hardware Repair Area 0 09-02-2006 07:55
k700i not flashing phpl HWK 1 02-28-2006 15:34
K700i not attatching simply-cy Cruiser Suite 7 01-26-2006 12:07
Page generated in 0.23148 seconds with 11 queries
