Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Sonics Box
Old 06-29-2005, 00:25   #16 (permalink)
AYMAN SHAMAYLH's Avatar
Member: 146798
Sonork: 100.1576177
Thanks Meter: 24
great update sonics
changing brown to red is great work
day after day sonics is the best
Old 06-29-2005, 02:30   #17 (permalink)
Member: 38039
Thanks Meter: 6
Originally Posted by fortipienz
NO SOPPORT K300I AMERICAN VERSION TESTED IN K700 AMERICAN VERION OK
K500 OK
V800 OK
K300I NOT WORKING :
Hi,
copy and post the log here, please. I'll try my best to help you.
best regards
Old 06-29-2005, 02:55   #18 (permalink)
andrew14's Avatar
Member: 78367
Thanks Meter: 11
Originally Posted by Redeagle
@andrew14:
Maybe you could do things as following:
1) RECOVER PHONE first, noting the certificate;
2) Flash with the V800_RED36_EROM_SSW.bin;
3) reflash the RED36_V800 flash file, i'll upload them tomorrow;
4) Unlock phone.
P.S., the V800_RED36_EROM_SSW.bin file attached.
best regards
my phone is cid 29 color red
ok ill wait that tomorrow as u say.............
Old 06-29-2005, 10:09   #19 (permalink)
Member: 38039
Thanks Meter: 6
@andrew14
Oh, your phone is RED CID29, no need wait till tomorrow.
Slight changes with the previous suggestions:
1) RECOVER PHONE with RED CID29 certificate;
2) Flash with the V800_RED29_EROM_SSW file, you can find it in the Sonics support zone;
3) Reflash the RED29_V800/Z800 flash file;
4) Unlock phone.
best regards
Old 06-29-2005, 10:22   #20 (permalink)
andrew14's Avatar
Member: 78367
Thanks Meter: 11
Thumbs down
a cid 29 v802se......
V800_RED29_EROM_SSW file, i hv flashd it already in firmware upgrade.
again i hv problem with this........
executing CS loader startup...
loader startup executed
executing CS loader filesystem startup...
csloader refused to start fs services.errcode: 1
Warning: failed, that is fatal
main and fs with rx1011 already flashed still dead...
z800? is it compatible?
recover phone log after "payload acknowledgement"............
SSW uses static hash, the number of used blocks is: 1
Going to flash 1 blocks...
remove and then insert battery now
current recovery file cid: 16
current recovery file cid: 29
phone recovery done, can reflash now.
Old 11-02-2005, 12:24   #21 (permalink)
Member: 131402
Thanks Meter: 18
@andrew14:
4) Unlock phone.
best regards
@Redeagle
You have this archive for p K300? I unlock one and was with the same problem:
Chip Id: 0x8000
CID detected: 36
Phone color: BROWN.
Speed: 115200 bps
Header acknowledged.
Prologue acknowledged.
Payload acknowledged.
loader startup: executed
csloader refused to start fs services,errcode: 1
Time elapsed: 482 secs
Old 11-08-2005, 12:21   #22 (permalink)
Member: 197368
dss 25 problem (t290i)
t290i unlock with dss 25
(pbb and semctool) error
Connect to phone
Check if RSA is active
Bypass boot authority
ERROR: 0001A7
help
Old 11-10-2005, 02:35   #23 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,337
same to me k300 not support cid 36 red try flash many times. SONICSTEAM do something what happen
RH-105 dp 5.71 support? Rastafari 69 HWK 3 11-30-2008 04:55
I have purchased a credit 1 week ago. the account has not arrived to me yet Seed88 KULANKENDI Server 5 08-17-2007 00:23
Panasonic x700-can the add to support? Virginia Infinity-Box 2 07-21-2005 07:17
The long waited SONICS 1.076 uploaded! Add LG3G support! Redeagle Sonics Box 61 05-03-2005 06:49
How to Flash the Samsung S-105 and V-205? kingofhearts Trident/AGERE Platform 3 04-12-2003 13:27
Page generated in 0.32332 seconds with 9 queries
